? Stuck throttle plate ?
Old Aug 31, 2014 | 07:09 AM
BarnieTrk's Avatar
BarnieTrk
Hey Fellas,
The truck in question is a '05, 4x4, 6.0L PSD, EB Excursion.
The last time I had it into the Stealership was to check out the lit CEL. They told me this truck has some sort of 'throttle plate' that is stuck open - causing the CEL to be lit. It isn't causing any engine performance issues, although the constant CEL being lit does cause me some anxiety.
Anyone with any thoughts on this?
Thanks in Advance, Guys!
BarnieTrk
Old Aug 31, 2014 | 07:45 AM
9228.bobcat's Avatar
9228.bobcat
Hmm. 05 doesn't have a throttle plate unless it's an 04 motor. What was the code?it would be under the intake elbow if you had one. Disconnect it.
Old Aug 31, 2014 | 07:50 AM
cheezit's Avatar
cheezit
Lots of thoughts.
Old Aug 31, 2014 | 07:53 AM
dlibson's Avatar
dlibson
'05 Ex motor will have it, as it's always an "04" motor so to speak.
If it were me, I'd delete the plate and not worry about it. If the plate is sticking due to build up, the code would go away. If the motor isn't moving it, it won't. Simply talking.
Also, a question, why is it people bring their trucks to the dealership, if they feel the need to call it a "stealership"? Always wondered that...
Old Aug 31, 2014 | 08:34 AM
merc82's Avatar
merc82
I don't have one, but I have hear of people gutting the throttle plate?
Old Aug 31, 2014 | 10:10 AM
npccpartsman's Avatar
npccpartsman
Did it over 200K miles ago and never had any issues.
Old Aug 31, 2014 | 02:51 PM
69cj's Avatar
69cj
My question also. I'd never take any vehicle to someone I didn't trust.
Old Sep 1, 2014 | 09:13 AM
BarnieTrk's Avatar
BarnieTrk
...why is it people bring their trucks to the dealership, if they feel the need to call it a "stealership"? Always wondered that...
Sounds like you guys are lucky and don't even know it; must be that your dealership takes care of you & your vehicle - otherwise you'd know why I refer to them as the 'stealership'. Sadly, the bottomline is I don't feel as though my local dealership has my best interest in mind. I get the feeling they are ONLY about the $$$.
You're both correct, I shouldn't go where I don't trust their judgement. I should simply take the truck to a dealership in the next town...
Nevertheless, thanks for your assistance with my question.
BarnieTrk
Old Sep 1, 2014 | 12:08 PM
joe blow's Avatar
joe blow
Removed mine 70k ago and not one issue
Grizzzzzzz
Sep 26, 2014 09:49 PM
clevelandjim
Apr 12, 2008 11:19 AM
Aaron Steinblock
Mar 6, 2008 09:44 PM
denman81
Nov 6, 2007 08:03 PM
blksiryder
Aug 3, 2007 11:14 PM
