No visible throttle plate, but still an actuator?
Old Mar 6, 2008 | 05:44 PM
Aaron Steinblock's Avatar
Aaron Steinblock
Went to do my egr unhook and throttle plate removal today. Took off the upper boot and there is no visible throttle plate (the photos in the instructions show a fraction of the plate extending up into the elbow). Took a curved screwdriver and swung it around in the lower half of the elbow and nothing there. There is, however, still a throttle body actuator right there at the elbow. I haven't taken apart the upper housing yet to see if something is in there and stuck in the down position.
If the throttle body is missing, will the actuator still be there?
Old Mar 6, 2008 | 08:06 PM
3000 FPS's Avatar
3000 FPS
Sounds like someone may have gotten to it before you did. They sometimes leave the actuator plugged in to prevent the truck from throwing a code. Really you need to pull the upper piece off like you said.
Old Mar 6, 2008 | 08:08 PM
Aaron Steinblock
Just pulled it off. No plate, no mounts for a plate, no nothing; but still a plugged in actuator outside????????
Old Mar 6, 2008 | 08:22 PM
otea090's Avatar
otea090
What year and build date is truck, early 04? Are there any pins inside the plugs when you unplug them. This is interesting as I have been told that if there is no plate then there would be no pins in the plug-ins. Like was said earlier you probably need to remove the elbow to see for sure.
Old Mar 6, 2008 | 09:16 PM
Aaron Steinblock
Early 03. Pulled the elbow off and no plate or mounting areas for one. Yes, there are pins in the actuator.
Old Mar 6, 2008 | 09:44 PM
4x4Mark's Avatar
4x4Mark
The '03 did not come with the plate installed. I think the housing is there for anticipation of need, but not actually implemented until '04.
Mark
