Serious Truck Problem!!
Old Sep 3, 2014 | 11:11 AM
  #31
351Cleveland C4's Avatar
351Cleveland C4
Originally Posted by Freightrain
This AIN'T right. The accel pump should point the fuel DOWN the carb. It should in no way hit the firewall.
Oh wow I totally missed that part! Yeah you got serious truck problems alright.
Old Sep 8, 2014 | 10:35 PM
  #32
F-ing 100's Avatar
F-ing 100
Okay problems solved and I feel like a total Dumb **s. Before I bought the truck, the previous owner added a new fuel switch for the cab. When he did this he accidentally put the hoses on backwards so when switched to AUX I was really running main and vice versa. But I didnt know about this so when I thought I was running on a full main tank, I was actually running a completely empty auxiliary tank. Thank God I found this out before dropping it off at the shop. Thanks for everyone trying to help.
Old Sep 8, 2014 | 10:49 PM
  #33
orich's Avatar
orich
Originally Posted by F-ing 100
Coils replaced, condensor is replaced. Shes in the shop now. I also noticed that when i gas it in idle, the jets squirt quite alot of fuel. it shot out of the carb (with the air filter off) and hit the firewall. I was thinking that maybe its flooding out. So maybe it just needs a carb/ jet adjustment
Ok so you found your goof up fuel line hoses.
But what about this gas squirting out onto the fire wall???
What Was is all about??
Orich
Old Sep 9, 2014 | 02:43 PM
  #34
JEFFFAFA's Avatar
JEFFFAFA
Orich
2X Orich. Mega imortante'. Sounds like a Holley carb the PO rebuilt. In doing so he installed the accelerator pump nozzle body upside down
Old Sep 9, 2014 | 04:29 PM
  #35
quinletc's Avatar
quinletc
3X
Inquiring minds...
Old Sep 11, 2014 | 05:10 PM
  #36
F-ing 100's Avatar
F-ing 100
Yeah it was squirting onto the firewall. its been working fine so far so i dont know if it will need an adjustment.
Old Sep 11, 2014 | 07:09 PM
  #37
JEFFFAFA's Avatar
JEFFFAFA
If this is a Holley look at the accelerator pump nozzle body. Open the choke flap. The accel body is in the middle of the carb's throat inbetween the front to barrels. front side of throat. Held down by a phillips screw. Out the side of this body pointing at the 2 barrels are the nozzles. Are they pointing a bit UP or a bit DOWN?
  #38
orich's Avatar
orich
If for some reason your truck was not to take the gas one morning and the engine spites or cough back up through the carb that comes with a back fire.
You may end up watching your nicely rebuilt truck go up in smoke & flames.
I guess You don't seen to understand the danger of your carb spraying upwards.. Oh well, I guess it's were just -ing in your ear.
Orich
Old Sep 13, 2014 | 07:17 PM
  #39
orstiers70's Avatar
orstiers70
I have a 72 f100 stepside and just had it worked on. My gas pedal was sticking though. Thought it was a linkage problem, was just a bad spring. Yah, cheap fix. Sounds like a linkage problem to me.
jxcasey
6.7L Power Stroke Diesel
69
Oct 28, 2023 09:09 AM
yert37388
Mar 16, 2015 08:06 AM
96ford250
13
Jul 17, 2013 10:33 PM
fastbee
May 9, 2011 01:31 PM
craterjoe
Sep 6, 2002 03:38 PM
