Serious Truck Problem!!
Old Aug 25, 2014 | 06:36 PM
F-ing 100's Avatar
F-ing 100
Hi I have a 2wd 1972 F-100 4spd. I just picked it up on the 23rd. She runs great but one problem... Today I drove into town and as I accelerated out of 2nd to make a turn my accelerator pedal didnt respond. Absolutely nothing. The engine was still running but it I eventually stalled it since I couldnt accelerate. I pushed it to the side and started up again like nothing even happened. At first I rubbed it off as a personal mistake until I was driving up a hill in 4th. I got over the top but the accelerator went out again. Did the same thing and she started back up again. This is not acceptable. If I cant fix this problem I might get in a serious accident. Someone please help me find the problem! I will try my best with any other needed information.
Old Aug 25, 2014 | 06:56 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by F-ing 100
Hi I have a 2wd 1972 F-100 4spd. I just picked it up on the 23rd. She runs great but one problem... Today I drove into town and as I accelerated out of 2nd to make a turn my accelerator pedal didnt respond. Absolutely nothing. The engine was still running but it eventually stalled since I couldnt accelerate. I pushed it to the side and started up again like nothing even happened. At first I rubbed it off as a personal mistake until I was driving up a hill in 4th. I got over the top but the accelerator went out again. Did the same thing and she started back up again. This is not acceptable. If I cant fix this problem I might get in a serious accident. Someone please help me find the problem! I will try my best with any other needed information.
The engine should still be able to idle regardless it could not accelerate.
After the issues, what did your visual inspection indicate with regards to linkage integrity, actuation, and fuel delivery?
Old Aug 25, 2014 | 07:01 PM
351Cleveland C4's Avatar
351Cleveland C4
yea if you can push the pedal and NOTHING happens, then you have a serious linkage problem.
Old Aug 25, 2014 | 07:04 PM
Missin'A Gear's Avatar
Missin'A Gear
Fuel filter could be clogged and steady building up back pressure until it restricts the line down to nothing. Would account for the lack of accelerator response and it starting up easily, only for the to happen again.
Seen this with older farm tractors.
Old Aug 25, 2014 | 07:08 PM
351Cleveland C4
but wouldnt that cause the engine to die with the throttle being wide open? wouldnt it lean out and not run? the way i understood it was that the engine was still running when he was pedaling it...
Old Aug 26, 2014 | 12:57 AM
F-ing 100's Avatar
F-ing 100
Yeah the Engine was still idling when it happened but Since I couldnt accelerate, I just had to keep down shifting and I eventually stalled it to get out and push it off the road. Sorry I worded that wrong. I didnt get a chance to check out the linkage but like I said it wouldnt accelerate when I put the pedal down. Is it also possible that maybe I didnt get the shifter into the actual gear (kinda between the gear and neutral) causing it not to accelerate? Someone said that might be the reason. If it is a linkage problem though, what should I look for?
Old Aug 26, 2014 | 01:19 AM
HIO Silver's Avatar
HIO Silver
Whether it is binding...or does it work as it should.
C'mon now dude . It sounds like posting your malady was your first step instead of being your own detective. Help us by helping you by having some skin in getting your rig figured out. Don't take this as being an azz but being self sufficient and learning how basic systems work pays back in a hurry. Dom't be afraid to tinker cuz you'll go broke in short order if you're a slave to a mechanic with a shop rate of $75 per hour.
R/.
Old Aug 26, 2014 | 01:37 AM
F-ing 100's Avatar
F-ing 100
Yeah I totally understand. Usually I do check this stuff out fast but I was also in a hurry today so I just parked it, put the post on hear and left again. Im gonna take a look tomorrow
Old Aug 26, 2014 | 06:51 AM
hillcountryflt's Avatar
hillcountryflt
Yeah, I know how something like that could fluster and frustrate someone. Especially when one is just getting their feet wet in working on these trucks. I am in the same boat. Big issues can have small causes.
I have a friend and fellow Harley rider. He was riding his Shovelhead and the thing just died. Put it on its jiffy stand and started checking wiring, thinking it was a coil. Reseated the wires and the bike started right up. He drove a few more miles and it did it again. He pulled over, dropped it on its jiffy stand and proceeded to check some more things. It started right up. This same thing happened one more time before he got home.
Ends up he was running of out of fuel. When he would lean his bike onto the jiffy stand, it would fill up the left side tank high enough to go into the regular/run position on his gasoline valve. He put the valve on reserve and all was good.
A simple thing that someone with his experience (and you get a lot of experience keeping old shovelheads running) should have picked up. Just something so simple, he did not consider it.
Old Aug 26, 2014 | 07:25 AM
60F100's Avatar
60F100
sounds like a fuel problem to me. Could be a clogged fuel filter but don't overlook that short piece of rubber hose under the cab that connects the hard line from the tank to the hard line to the fuel pump. They deteriorate over time and will collapse. will give these exact symptoms. Another remote possibility is trash floating in the gas tank. Flakes can get caught on the bottom of the pickup tube due to the vacuum caused by the pump. when it stopped it will float away until vacuum returns.
Old Aug 26, 2014 | 10:38 AM
orich's Avatar
orich
All lot of these trucks get posted 4 sale when something goes wrong, and the owner can't figure it out or don't want to put money into the old family vacation truck that now just sits along side the house.
I'd start by replace all rubber fuel lines fuel filter inside the lower fuel pump canister.
Orich
Old Aug 26, 2014 | 11:35 AM
F-ing 100's Avatar
F-ing 100
I looked at the linkage this morning. Everything seemed to be fine there. After work Ill take a look at the hoses underneath. If I still cant find the problem, Im gonna take it to the mechanics shop where the entire engine, carb, tanks, fuel lines were all replaced/rebuilt about 4000 miles ago.
Old Aug 26, 2014 | 03:29 PM
JEFFFAFA's Avatar
JEFFFAFA
I agree on the fuel starvation theory. How long had the truck sat before you bought it? Got OLD gas in it still? 1st I'd replace the fuel filter. Check out the old one to see if there's any mud,rust,scale,or old bits from the inside of the rubber hoses. 2X on changing all the rubber hoses anyways. When was the last time it got a COMPLETE tune-up? All fluids changed? I like to do all this so I got a fresh baseline. My .02.
Old Aug 26, 2014 | 06:04 PM
flyboy2610's Avatar
flyboy2610
Sounds like you've got something in your gas tank that is clogging the fuel pickup. When the fuel pump is putting suction on it, it clogs the inlet. When the pressure is removed the junk falls off and the engine responds normally, until the junk gets sucked onto the inlet again.
I had this happen while driving a diesel powered straight truck at a previous job. They cleaned out the tank, problem solved.
Old Aug 26, 2014 | 07:12 PM
Malakilla's Avatar
Malakilla
Step one for me would be to verify the entire linkage is 100% free and clear and has no loose or binding parts. Second part would be to have a clear fuel filter and start the truck.... prop open the throttle a bit and watch. If the filter stays full and flowing, you know the issue is likely in the carb somehow.
If the filter starts thinning out and showing a lack of fuel flow, then either it is clogged, or the rubber line is cavitating, or the tank is shedding the rust scale. I had the last one happen to me and had to source a replacement tank. Rust clogged the filter on my transfer pump on my way home from Michigan. I hate being stuck in Ohio
