Cel...
Old Aug 21, 2014 | 01:01 AM
kylek95's Avatar
kylek95
Cel...
So 1995 460
it runs great but the check engine light is coming on showing code 173 for running too rich. So far i have replaced the o2, replaced a vacum thing (cant think of the name of it right now) and i replaced the tps. This is where it gets kinda trickey...Runs great but even when i unplug the o2 and run it around about 15 minutes into driving the light still comes on for the code 173 so is there another sensor somewhere that picks up / caculates the richness? Thanks
Old Aug 21, 2014 | 01:02 AM
kylek95's Avatar
kylek95
Oh and i forgot the fuel pressure is GOOD about 32psi at idle and 40i when you unplug vacum from the regulator.
Old Aug 21, 2014 | 01:09 AM
85e150's Avatar
85e150
WAG alert. T-stat issues, running too cold causing the EFI to stay in rich mode for warm up. Or temp sensor issues so it thinks it's cold but it ain't.
Old Aug 21, 2014 | 01:21 AM
kylek95's Avatar
kylek95
Yep brand new 190 tsat and coolant temp sensor the needle sticks almost straight up on temp gague...any more ideas?
Old Aug 22, 2014 | 01:06 AM
kylek95's Avatar
kylek95
SOMEBODY has had to have had this happen to then before????? The 173 code comes.on even when i clear the codes and run it around with the o2 unplugged. Anyone wanna take a stab at what it could be?
Old Aug 22, 2014 | 11:03 AM
85e150's Avatar
85e150
Was there an "event" after which all this started?
Have you checked your connections, making sure the voltage from the O2 sensor is being read?
Does it have EGR? Checked that?
Checked for vacuum leaks everywhere, especially manifold to heads?
You are correct, this is a common problem.
Rough idle and running very rich - FSB Forums
https://www.ford-trucks.com/forums/1...le-idle-2.html
IAC was a problem. Different year, not sure how that translates to your truck or if you have an idle air control.
Old Aug 22, 2014 | 11:12 AM
85e150's Avatar
85e150
Forget the above unless this doesn't work. Purge solinoid, read on:
https://www.ford-trucks.com/forums/1...172-173-a.html
Deeply analytical:
https://www.ford-trucks.com/forums/4...ivability.html
Fuel pressure regulator:
https://www.ford-trucks.com/forums/1...ease-help.html
Old Aug 22, 2014 | 07:26 PM
kylek95's Avatar
kylek95
Checked just about everything else you listed. How would i check the o2 wireing and where because it goes on top of the transmission and i dont know where it goes from there. Also what should the voltage be? And sometimes when im driving it the light will flick off for like 30it secs. But with no change in preformance or and it did it 2 different times randomly.
Old Aug 22, 2014 | 11:50 PM
85e150's Avatar
85e150
Scroll down to "... Diagnosis"
What the Home Mechanic Needs to Know about O2 Sensors
More of the same:
http://densoautoparts.com/sites/defa...ing%20tips.pdf
Short version, between 0 and .9 volts.
The sensor wires go into the engine computer. Might be hard to trace or follow them.
ingram
Oct 6, 2017 10:05 PM
offrdmania
Jan 26, 2016 06:38 PM
statetrooper
Jan 29, 2012 09:34 PM
LukeRips
Dec 2, 2006 10:29 PM
bgblktruk
1978 - 1996 Big Bronco
Jun 10, 2002 08:28 PM
