So 1995 460
it runs great but the check engine light is coming on showing code 173 for running too rich. So far i have replaced the o2, replaced a vacum thing (cant think of the name of it right now) and i replaced the tps. This is where it gets kinda trickey...Runs great but even when i unplug the o2 and run it around about 15 minutes into driving the light still comes on for the code 173 so is there another sensor somewhere that picks up / caculates the richness? Thanks
WAG alert. T-stat issues, running too cold causing the EFI to stay in rich mode for warm up. Or temp sensor issues so it thinks it's cold but it ain't.
SOMEBODY has had to have had this happen to then before????? The 173 code comes.on even when i clear the codes and run it around with the o2 unplugged. Anyone wanna take a stab at what it could be?
Checked just about everything else you listed. How would i check the o2 wireing and where because it goes on top of the transmission and i dont know where it goes from there. Also what should the voltage be? And sometimes when im driving it the light will flick off for like 30it secs. But with no change in preformance or and it did it 2 different times randomly.
