1978 - 1996 Big Bronco
Changed the O2 sensor and still getting a 41 code
Old Jun 10, 2002 | 05:54 PM
bgblktruk's Avatar
bgblktruk
This weekend I replaced my oxygen sensor and the intake air temp sensor on my 88. I had been getting a check engine light so I pulled the codes and got a 24 and a 41. The 24 is the intake air temp. sensor out of range and the second is HEGO sensor out of range always lean. I knew the O2 sensor was old so I decided to change out both. The IAT was dirty and smelled like gas. So when out this weekend I got the check engine light again so I pulled them and found the 41 code still coming up in both memory and during the engine running test. I want to know why its registering lean and does that mean the computer will be compensating and making it run rich? Any help or ideas would be appreciated.
Old Jun 10, 2002 | 08:28 PM
Pioneer Ford's Avatar
Pioneer Ford
