1992 Ford F-150XLT. Speedometer Problem.
Old Aug 19, 2014 | 02:36 PM
Christopher Boyum's Avatar
Christopher Boyum
Post 1992 Ford F-150XLT. Speedometer Problem.
I've Already Replaced the VSS Censor and the Speed Modual on the Dash bord My Speeometer still bounces over 30 MPH. What else should i look at replacing
Old Aug 19, 2014 | 06:28 PM
Encho's Avatar
Encho
The Southernmost Mod
Hello, and welcome to FTE! Try taking the rear differential cover off, then you can check the tone ring, it's the one that feeds the signal to the VSS, if it has broken teeth it will send wrong readings, resulting in a bouncing needle at the speedometer. Otherwise you might be looking at a PSOM issue.
86moneypit
1997 - 2003 F150
May 14, 2013 10:46 PM
ramrod7373
15
Apr 1, 2013 11:37 AM
kjf-250
May 24, 2009 06:36 PM
mack9truck
Nov 4, 2007 06:43 PM
mx711
Apr 7, 2006 08:16 PM
