Speedometer problem 1996 F150
Old Nov 3, 2007 | 08:08 AM
mack9truck's Avatar
mack9truck
Question Speedometer problem 1996 F150
Can someone help..My speedometer fluctuates once I reach 65 MPH back and forth 5 miles. I have changed the speed sensor in the rearend. My truck is also a 2 wheel drive. Truck runs great just this problem. Any advise will be greatly appreciated.
Old Nov 3, 2007 | 08:24 AM
lostin90s's Avatar
lostin90s
Welcome to FTE . You your posom (center cection "speedo") May be going bad . You could try swapping another in to check .
But wait for more posts . There are guys on here that know just about every thing about these trucks . Good luck
Old Nov 3, 2007 | 10:34 AM
subford's Avatar
subford
You either have a bad PSOM, Speedometer Head or tone ring in the rear end.
You need to put it on jack stands and put a scope on the VSS signal coming from the rear end. See if the pattern changes while you hold the speed constant and the speedometer is jumping.
You could also use a frequency meter.
Old Nov 4, 2007 | 06:43 PM
mack9truck's Avatar
mack9truck
Thanks
I will try this and post back with my findings. I appreciate the info.
chzuck
2004 - 2008 F150
Aug 16, 2015 11:32 PM
50trucking
Sep 23, 2014 03:13 PM
mitch199077
Jun 9, 2014 04:03 PM
dooleyservices
16
May 2, 2014 11:24 PM
howardsamycia
Mar 1, 2014 12:20 PM
