Trouble starting
Old Aug 14, 2014 | 08:34 PM
oldwiley's Avatar
oldwiley
Trouble starting
Hi All. This is my first post on here so hopefully it works. The problem I have is with a 1958 f100 project I am working on with my dad. When I turn the key to start the truck you have to let it turn over a few times then let of and the engine will start after you have let off the starter. If I keep it all the way over so the starter is winging it won't start. I have changed the key switch and the problem still persists. I am thinking there might be an issue with the solenoid. Any thoughts or suggestions would be helpful.
Old Aug 15, 2014 | 04:45 PM
Damifiknow's Avatar
Damifiknow
Make sure all the wiring to dizzy and starter solenoid are tight and not broken. Points set right? Sure you got the ignition switch wired right? Electrical troubleshooting sucks. Goodluck.
Old Aug 15, 2014 | 09:30 PM
oldwiley's Avatar
oldwiley
Thanks for the reply Damiflow. I actually got it to work right today. Whoever wired it up last really had things messed up. Now on to the next issue.
LRSTony
1997 - 2003 F150
Jun 11, 2015 03:40 PM
gordo777
2004 - 2008 F150
13
Apr 13, 2015 07:42 PM
73strokin
Oct 28, 2007 09:21 AM
62Cole
Mar 14, 2006 02:09 AM
dwill49965
1983 - 2012 Ranger & B-Series
May 14, 2005 01:00 PM
