oil coolers
Old May 3, 2004 | 02:08 AM
averagef250's Avatar
averagef250
oil coolers
Does anybody make a thermostatically controlled oil-air oil cooler? I swear I've seen one of these before so you're not running cold oil through the cooler before your engine heats up. Also, would an oil-coolant heat exchanger like big trucks and diesels use be better? Was there ever a factory oil cooler on an fe or ft engine?
Old May 3, 2004 | 09:38 PM
Putt's Avatar
Putt
I have seen a therm controlled valve for routing oil to the cooler...try Hayden I think. I have an oil temp gauge on my '66 with 428 and never saw any more than 200* oil temp even pulling in the summer. So I haven't looked into the engine oil coolers.
