i dont know sir no throttle going down road ficm is at 48 and got these codes p2104, p2123, p2138, p2139 & p2140 so I am assuming throttle sensor is bad.. is there a way to check it once i figure out were the heck it is..
A actual seperate TPS is no longer used or even exists. It is part of the function of the APP. The app tells the pcm how much throttle your foot is demanding and the pcm tells the injectors what to do accordingly.
There is no direct connection to the engine and the accelerater pedal.
No more cable just electric wires.
