Throttle Position Sensor?
Old Jan 16, 2005 | 02:04 PM
matt3763's Avatar
matt3763
I've been having a problem recently with my 95 Ford F150. Soemtimes when i go to step on the gas, i get no response, no movement and no rev. Also when i'm driving sometimes, it will begin to slow down and i have to press down hard on the gas to get it going again and then it jumps into passing gear right away. This only happens once and a while. I was wondering if it could be the Throttle Position Sensor?
I'm new with my truck, so and not very educated on it. Need some help with this problem. Thanks.
Old Jan 16, 2005 | 02:24 PM
Kansas-Mike's Avatar
Kansas-Mike
What kinda codes are you getting?
Old Jan 16, 2005 | 04:57 PM
guzzler96's Avatar
guzzler96
Lightbulb
Do a search by either TPS or Throttle Position Sensor and you should be able to find a test procedure for the TPS. If you can get a hold of an automotive multitester, like a Fluke 78,etc., you can check the TPS with it.
guzzler96
Old Jan 16, 2005 | 05:33 PM
matt3763's Avatar
matt3763
I have nothing to check the codes with and would prefer not to buy any
Old Jan 16, 2005 | 05:42 PM
Kansas-Mike
Go to Autozone.... They will do it for free...
Old Jan 16, 2005 | 05:47 PM
guzzler96's Avatar
guzzler96
Lightbulb
Then go to fordfuelinjection.com and read up on how to check for codes using the sti plug and the CEL (Check Engine Light) or go by Autozone and see if they can check them for you. There is a lot of really good info on the ford site. Take note of the best viewed resolution they say. The majority of internet stuff is 800 x 600, but the higher resolution on the fordfuelinjection.com site will view better. Autozone will probably say if the CEL is not lit they can't read codes. There are (3) types of codes, however, KOEO (Key On Engine Off), CM (Continous Memory) and KOER (Key On Engine Running). The fordfuelinjection.com is worth looking a most all of it.
guzzler96
Old Jan 16, 2005 | 06:33 PM
matt3763's Avatar
matt3763
Thanks guys for the help, ill run to autozone probably tomorrow to get it looked at
Old Jan 16, 2005 | 06:35 PM
matt3763's Avatar
matt3763
Either of guys know the easiest way to get to the TPS to replace it on a 95 Ford F150 5.0L 4x4??
Old Jan 16, 2005 | 08:32 PM
fordgta's Avatar
fordgta
i took the throttle body off and flipped it towards me. thers like 4 bolts a couple vacuum ,lines and on she goes
Old Jan 17, 2005 | 06:49 AM
guzzler96's Avatar
guzzler96
Lightbulb
I would agree that removing it would make it a lot easier to get to the fasteners. You might have a little problem finding a throttle body gasket that is not in a set. I know a gasket comes in an upper intake gasket set for about $12, but don't know if they have one separate.
guzzler96
blueray
24
Apr 13, 2013 07:54 PM
Offroadmaniac
2004 - 2008 F150
Jan 27, 2011 08:07 PM
runner
13
Oct 6, 2006 04:15 PM
Wdkask
Sep 24, 2003 01:05 AM
BlueEagle
23
Jun 27, 2003 01:21 AM
