Cautionary temps while towing. Need input right away please
Old Jul 26, 2014 | 10:27 PM
BLADE35's Avatar
BLADE35
your going to be Fine
Temps Look Great
Josh where you get 1300* EGT* Just a Randon number amonst similar turbo charged trucks???
our turboes are tuff as far as Heat goes
To me EGT is a great gauge to spot overfueling inject
Old Jul 26, 2014 | 10:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Temps Look Great
It's valves, head gaskets and pistons to be concerned about with elevated EGT, couldn't care less about the turbo.
Josh
Old Jul 26, 2014 | 10:49 PM
BLADE35's Avatar
BLADE35
deleatemehjjjj
Old Jul 26, 2014 | 10:53 PM
BLADE35's Avatar
BLADE35
I also thinking along those lines
Some seam to focus on turbo/EGT* to much ya know
Old Jul 27, 2014 | 09:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That IS steep! It averages 10.2%.
You can run the transmission as high as 220F ALL DAY LONG with no problems. You can go as high as 250F for no more than a half hour at a time. Chances are you won't get to these temperatures.
Old Aug 3, 2014 | 12:50 AM
olfordsnstone's Avatar
olfordsnstone
Just got home. The truck ran beautifully. EGTs got up around 1150 - 1200 going up over Tioga Pass to Yosemite. When EGT got up there, I just backed off on the accelerator a little and it would drop right back down, usually staying well below those temps. Transmission found the sweet spot for RPM on her own. I used Matt's unlimited tow tune (gearhead). I was amazed at how cool she ran, actually. On the way home we took a different route and there were a few good grades as well. Ambient temps were around 104* and the truck pulled the hills like a dream and stayed nice and cool. I think the highest oil temp was around 129*, though I didn't really watch too closely as I had the alarm set for overtemp.
Thanks again for all of the advise.
Old Aug 3, 2014 | 03:58 AM
Edogsf350's Avatar
Edogsf350
did you mean 239 DEG
Old Aug 3, 2014 | 10:24 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Or 229 degrees?
Old Aug 3, 2014 | 10:31 AM
BLADE35's Avatar
BLADE35
I Assume he Ment EOT 229*
What Isuspect is he got closer to the ECT221* defuel point However its a Suttle defuel meaning most don't notice but should have reduced FPW & EGT
and ECT*???
Old Aug 3, 2014 | 12:35 PM
olfordsnstone
Oops, yup 229*.
gotroxs
Sep 3, 2024 03:11 AM
RideDiesel88
Sep 27, 2012 04:57 PM
MC5C
Jul 30, 2012 05:44 PM
Bob2626
Dec 31, 2011 09:43 PM
fireman660r
Dec 13, 2010 08:43 PM
