Acceleration Issues
Old Aug 2, 2014 | 12:37 PM
PappyUSMC's Avatar
PappyUSMC
Question Acceleration Issues
2003 Ford F250 XLT Super Duty - Acceleration Issue
83K miles. Purchased 3 months ago.
Recently when we hit about 1800 RPMs to about 2600 RPMs the truck hesitates and makes a woosh sound in the engine. Additionally, when holding speed, the normal whistle gets a bit higher pitched and then drops down every 2.5 seconds.
There is also a point where the normal whistle becomes a dull tone.
Has happened two days now, first a couple months ago and then yesterday/today. Both times it was raining.. possibly coincidence.
Please no "Thats what you get for buying a 6L" or "buy a new truck" posts.
Any input is appreciated.
Old Aug 2, 2014 | 12:38 PM
PappyUSMC's Avatar
PappyUSMC
Video is currently uploading.
Old Aug 2, 2014 | 02:30 PM
jswartz84's Avatar
jswartz84
That's not a response you will get around here.
Old Aug 2, 2014 | 02:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sounds like one of the CAC tubes has a split in it...... what was your boost gauge doing at that time? The vidio didn't go low enough to see it.
Old Aug 2, 2014 | 04:47 PM
PappyUSMC's Avatar
PappyUSMC
I don't have a boost gauge.
Old Aug 2, 2014 | 04:49 PM
PappyUSMC's Avatar
PappyUSMC
That's awesome.
Old Aug 2, 2014 | 05:05 PM
BLADE35's Avatar
BLADE35
sounds like turbo is stuck
But you need a Gauge to check the turbos Control sensors
BARO
MAP
MAFV
vgt
Old Aug 2, 2014 | 06:00 PM
PappyUSMC's Avatar
PappyUSMC
Any way to figure this out without new gauges?
Old Aug 2, 2014 | 06:35 PM
Edogsf350's Avatar
Edogsf350
thats the worst case of turbo fart i have seen
Old Aug 2, 2014 | 09:55 PM
PappyUSMC's Avatar
PappyUSMC
Whats the cause and how do I fix it?
Old Aug 2, 2014 | 10:26 PM
9228.bobcat's Avatar
9228.bobcat
Veins sticking from coking or rust. Good cleaning should help
Old Aug 2, 2014 | 11:08 PM
Edogsf350's Avatar
Edogsf350
like blade35 said you need to check the sensors that operate the turbo. and like bobcat said the turbo probably needs cleaned, and that info can be found in the tech. folder
you probably have the inferred EBPV as i do so that sensor value cant be used.
Old Aug 3, 2014 | 09:02 AM
PappyUSMC's Avatar
PappyUSMC
Alright, I will start doing some research to figure out how to do those things...
Thanks all!!
Old Aug 3, 2014 | 09:39 AM
cornstar6207's Avatar
cornstar6207
Check your cac boots and tubes for problems also.
Old Aug 3, 2014 | 10:04 AM
BLADE35's Avatar
BLADE35
You can use a DVM
Digital Volt Meter
But you would need to study each sensor and have a Wire Diagram
Its going to be a LONG Process this way^^ AutoZone sells ScanGaugeII
Tell me this Do your Veins Sweep at Idle?? Its a Change in the exhaust Tone every 1 minute or so
