intermintent miss
Old Sep 11, 2003 | 07:03 PM
smithd's Avatar
smithd
intermintent miss
The hose and COP (coil on plug) both were shot. Did not hold up to amp test.
Old Sep 17, 2003 | 09:48 AM
smithd's Avatar
smithd
intermintent miss
My check engine light was on because my buddie hooked up a wire to a solenoid wrong--hard to notice under the intake manifold in the front on the right. The APG (? on name) was not hooked up as a result so the check engine light came back on steady. A code was returned after hooking it back up and pointed us to the problem. The end solution was indeed to replace the heater hose over the #4 cylinder coil, the coil (COP), and the vacuum hose assembly that had two leaks. Yay!
Old Sep 17, 2003 | 04:55 PM
horseman1's Avatar
horseman1
intermintent miss
I replaced 4 cops and 4 plugs, trouble went away, now I'm going to use #1 on passanger side to find exactly which if any of the coils are bad by changing them out until the problem comes back.
them coils...
Old Sep 17, 2003 | 07:55 PM
smithd's Avatar
smithd
intermintent miss
I think an analyzer will tell you which coil is bad, if any. But, sounds like you are doing ok now. Good luck!
Old Mar 4, 2005 | 11:26 PM
Grunt99's Avatar
Grunt99
Smithd how did you do a amp test on a cop, i piulled all eight cop's on my 2002 expedtion today and did resistance readings on them reading .7 to .8 on primary and 5.3k to 5.4k on the secondary.
Old Mar 5, 2005 | 07:00 PM
smithd's Avatar
smithd
Grunt99,
You need to get it on a big time analyzer check it. No other way that I know of - and it was so long ago I don't remember the exact procedure my buddy used once he got it on the analyzer. I know the plug and cop closest to the passenger seat was the problem. Fortunatly, my buddy has a garage shop and an analyzer, and does not charge unless he fixes the problem. Most places will charge you just to put it on an analyzer - so you might just want to go forward with the fix (cop, hose/wire, and plug). If you are real lucky you might find a parts store near you that will give you a complimentary hook up - but it sounds like you have some sort of gizmo already. Good luck!
Old Mar 5, 2005 | 07:52 PM
Grunt99's Avatar
Grunt99
thanks smithd, i just wanted to go through everything that i can do before i have to take it to someone else, I do not realize that the post that put on the tail end of a post that ended in 9-03, one again thank you, basically i ust used a volt ohm meter to measure the resistance of the primary and the secondary of the cop,
bit422
1983 - 2012 Ranger & B-Series
Jul 16, 2009 09:22 AM
952X4
13
Nov 18, 2008 07:54 AM
dennisdoc
1997 - 2003 F150
Mar 20, 2008 09:56 PM
kdwilkes
17
Feb 3, 2007 03:12 PM
craigthowell
Modular V8 (4.6L, 5.4L)
Aug 17, 2003 01:05 AM
