Hydroboost Leaking
Old Jul 22, 2014 | 07:20 AM
iron1951's Avatar
iron1951
Hydroboost Leaking
My Hydroboost is leaking inside the passenger compartment through the firewall. Am I looking at a new unit or can this one be repaired? Is one from the wreckers a good idea or not? No issues with the brakes, just the leak. Thanks
Old Jul 24, 2014 | 05:22 PM
iron1951's Avatar
iron1951
Well I went to the u-pick wreckers today and picked one up for $75. Hope this does the job. Would like to rebuild my old one because it worked well. No issues. Only the leak where the rod from the brake pedal goes into the hydro-boost unit. Anyone know where a rebuild kit can be had?
Old Jul 24, 2014 | 05:26 PM
69cj's Avatar
69cj
Was it leaking brake fluid or atf fluid?
Old Jul 24, 2014 | 07:25 PM
iron1951's Avatar
iron1951
It was leaking ATF. I had stuffed some paper towels under the carpet and underneath the hydro-boost. It was definitely red and smelt like ATF. A shame I can't just replace a seal because the hydro-boost is not giving me any problems. I have not put in the unit I bought at the wreckers yet. In a few days when I get time.
Old Jul 25, 2014 | 07:18 AM
69cj's Avatar
69cj
I would think that there are rebuild kits for them.
Old Jul 25, 2014 | 07:29 AM
iron1951's Avatar
iron1951
You would think so. I was hoping some one would point me to a source. I have been searching the net.
Old Jul 25, 2014 | 08:03 AM
429SCJ's Avatar
429SCJ
Try piratejack.net
Old Jul 25, 2014 | 09:24 AM
iron1951's Avatar
iron1951
Thanks for the link. I can now see why the whole unit gets replaced when there is a problem. After reading the service instructions and determining that I have a staked pedal rod, it looks like I would also have to buy an input rod kit and a replacement pedal rod. So I figure, after all that a rebuilt unit may be the way to go. Too bad that the pedal rod was not of a design that would allow for easy disassembly/assembly of the hydroboost unit. Being that this is brakes, I would not want to mickey-mouse the pedal rod and have it fail while I am driving. If the wrecker unit does not do the job, I do not feel so bad about paying for a rebuilt unit. Thanks
jmaskew
Nov 30, 2015 02:20 PM
jdm5630
6.4L Power Stroke Diesel
Jul 27, 2015 09:26 AM
sudsmcduff
Aug 29, 2013 08:27 PM
66crawler
17
Mar 27, 2012 07:31 PM
miller_feed
Sep 14, 2007 12:03 PM
