Hydroboost ATF Leak
Old Nov 28, 2015 | 12:21 AM
jmaskew's Avatar
jmaskew
Hydroboost ATF Leak
I have had ATF underneath the Hydroboost for a few years now. Its not a bad leak but it does drop sometimes off the bottom of the unit. I have checked all the hose connections and they are dry. It is leaking only from the bottom area. Back in 2007 I had the cab off so the dealer could fix the headgaskets. Is there any o-rings or gaskets between the master cylinder and Hydroboost?
Old Nov 28, 2015 | 08:17 AM
TooManyToys.'s Avatar
TooManyToys.
Between them, no, just the seal in the HB itself. With the cab off you have a higher chance that one of the many o-rings for the line fittings is damaged. If it's definitely not from the line then the best choice is a new HB unit.
Old Nov 28, 2015 | 08:42 AM
Ford_Doctor's Avatar
Ford_Doctor
The brake booster is not serviceable. As Jack stated, check the lines first and is okay you will need to replace the booster. It is not a bad job. You can use Mercon 5 ATF or PS fluid to refill the system.
Old Nov 30, 2015 | 02:20 PM
jmaskew's Avatar
jmaskew
Thank you guys for the replies!! Yesterday I decided to take the Master Cylinder off the hydroboost unit to see where the leak was coming from. There was a trail of ATF on the inside that leads to the little hole in the bottom of the unit. So I cleaned the master cylinder and the hydroboost up and put them back together. I don't know what I did but the leak is gone. Usually when I clean the fluid off the bottom it comes back immediately as soon as I take it for a drive. I drove it twice yesterday, parked in the garage and applied brakes and turned the wheel back and forth in he driveway several times and nothing. I'm glad but puzzled!! lol
Nor_Cal6.0
Mar 20, 2015 02:55 PM
okie72
Feb 15, 2014 09:35 PM
GotThreeOfThem
Sep 1, 2012 11:53 AM
77ford guy
Apr 10, 2006 11:33 AM
