hydroboost leak
Old Aug 26, 2013 | 05:38 PM
sudsmcduff's Avatar
sudsmcduff
hydroboost leak
just notice a leak on driver floormat. leaking from piece just above the pedal. it is not coming from up top of brake pedal shaft. looks to be power steering fluid. cant find much on this on the web. thanks for any help.
Old Aug 26, 2013 | 06:32 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I just recently found a similar leak on mine. We have Trans fluid (red) in our hydroboost system. The fluid leaking on yours is clear and it is not brake fluid? correct? If it is I have the same leak.
Old Aug 26, 2013 | 06:43 PM
sudsmcduff's Avatar
sudsmcduff
mine is red.
Old Aug 26, 2013 | 06:52 PM
Crewcab Turbo
Red, that makes sense, definatly a hydroboost leak. As far as I know there are no replacement seals available. Replacing the hydroboost unit is the only option.
Old Aug 26, 2013 | 07:10 PM
sudsmcduff's Avatar
sudsmcduff
sweet. already broke and sore from the gt38 install last weekend. wonder if i flush the power steering system and put some lucas stop leak in there.
Old Aug 27, 2013 | 02:57 AM
USMCJosh's Avatar
USMCJosh
just replace the bad component. Stop leak or any of that other junk is a waste of money
Old Aug 29, 2013 | 08:27 PM
srteach's Avatar
srteach
... and can cause other problems, including new parts requirements.
BAD RONALD
18
May 25, 2019 03:58 AM
ryanparhaniemi
Jun 17, 2016 01:35 PM
Dirt-Road-Kid97
Oil & Lubrication
Jan 20, 2014 01:00 AM
mrwrench
Dec 23, 2010 09:06 PM
miller_feed
Sep 14, 2007 12:03 PM
