This morning on the way to work I got on it to pass some yoyo and was the first time I noticed a puff of light black smoke. I was up to temp and everything seems to be running fine. I went to the store here at lunch and when I got back and parked I rev'd it up just for grins a few times and saw the puff again (wasn't up to full temp). I'm at 140K now and FICM stays in the 47.5 to 48 range always also so do I need to start looking into contribution test, egr clean, turbo clean, check EBP or any other value or let it be?
When I had an EGR cooler I could always at least haze an intersection with a WOT run. It's just the nature of having a gas inlet after all the sensors that measure airflow into the engine. Pull and clean the EGR valve if you've never seen it outside the engine bay and that will probably fix you up. Adding an EGT gauge will check for any boost or exhaust leaks.
