VIN decode
Jul 15, 2014 | 03:16 PM
Jul 15, 2014 | 07:13 PM
Quote:
Originally Posted by
Pireaux
Please decode this rating plate with VIN?
Warranty Number: F10CR383059 / Warranty Plate: W.B. 122 / COLOR: M / MODEL: F100 / BODY: 66B / TRANS: B / AXLE: 12 / MAX GVW LBS: 5000 / CERT NET HP: 135 / RPM: 3600 / DSO: 71
F10 = F100 2WD.
C = 292 2V.
R = San Jose CA Assembly Plant.
383059 = 1963, assembled February 1963.
122" Wheelbase.
M = Corinthian White.
F100 2WD, 5,000 lbs. GVWR.
66B = Uni Custom Cab.
B = Borg Warner T-86 3 Speed Manual with Overdrive Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,600 RPM / RPM on plate is hard to read, it could also be 3800, but it's not 5000.
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Jul 15, 2014 | 07:29 PM
Decode thanks for 63 uni
Thanks for the great info. That was a quick reply too!
Jul 15, 2014 | 08:03 PM
122 wb on decode
The 122 means LB right? What is the number for SB?
Jul 19, 2014 | 10:42 AM
Sorry To Hy-jack, but NumberDummy, could you also decode my vin tag as well? I was told you were the go-to guy
F35CE502790
132 M F350 F81 G 23
10000 135 1800 11
Thank you in advance
Jul 19, 2014 | 11:06 AM
ihcc104
F35CE502790 / W.B. 132 / COLOR: M / MODEL: F350 / BODY: F81 / TRANS: G / AXLE: 23 / MAX GVW LBS: 10000 / CERT NET HP: 135 / RPM: 3 800 / DSO: 11
F35 = F350.
C = 292 2V Medium Duty.
E = Mahwah NJ Assembly Plant.
502790 = 1964, assembled February 1964.
132" Wheelbase.
M = Wimbledon White.
F350, 10,000 lbs. GVWR
F81: F = Black all Vinyl / 81 = 81B Custom Cab.
G = FX Cruise-O-Matic.
23 = Spicer/Dana 70 Rear Axle / 5.13-1 / No Limited Slip / 7,400 lbs. Rear Axle Capacity.
10,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
Jul 19, 2014 | 12:08 PM
Thank you! You were definitely the right guy for the task!
mhu
May 11, 2015 03:14 AM
Argie66
Dec 11, 2014 09:36 PM
breedo99
Jan 28, 2014 08:40 PM
cheddar89
Mar 8, 2012 09:13 AM
dullchrome
Jan 27, 2009 11:11 AM
