Voltage Regulator + Condensor?
Old Feb 22, 2017 | 12:49 PM
daveengelson's Avatar
daveengelson
Alternator gauge readings have been all over the map, swapped voltage regular from my other 65 and seems to have solved the issue. Now looking for a replacement and I assume the condenser is necessary, if so, would a condenser for the alternator work? Appreciate suggestions as to source for both regulator and condenser.
Thank you in advance!!
Old Feb 22, 2017 | 01:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Point type alternator voltage regulator same 1963/64 Thunderbird and 1965/81 everything.
In 1982, Ford replaced the point type regulator w/an electronic regulator, wiring harness is the same.
The 'condenser' mounted on the regulator is actually a "radio voltage regulator noise capacitor."
Old Feb 22, 2017 | 02:10 PM
daveengelson
Imagine I have the 'mechanical' variety voltage regulator, same regulator thru these many years. Will take original to compare.
Thank you Bill!!
tequilaq
Electrical Systems/Wiring
Dec 25, 2006 11:58 AM
fatjoe216
Nov 1, 2004 08:23 AM
19644x4
Jan 8, 2004 03:27 AM
Sawbones25
Jul 4, 2003 08:00 PM
