woodbed
Old Jul 10, 2014 | 10:50 PM
arrowheadfred's Avatar
arrowheadfred
woodbed
Hey guys' my woodbed looked great when done it. I used spar finishing but the FL. Sun eat it up. I have removed it and I'm putting in new boards. I don't want to use the same stuff so what should I use? I thought about going back to nature and useing linseed oil. Anyone know of a good product. ?????
Old Jul 10, 2014 | 11:53 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Welcome back! Long time no see.
I know Ax was just telling someone about this recently. I'll see if I can find the thread.
Yeah here's one. It's for tung oil instead of linseed.
https://www.ford-trucks.com/forums/1...-question.html
Hope this helps.
Old Jul 10, 2014 | 11:58 PM
Jolly Roger Joe
Here's another on about tung oil...
https://www.ford-trucks.com/forums/1...installed.html
Old Jul 10, 2014 | 11:59 PM
Jolly Roger Joe
But this is the one I was looking for.
https://www.ford-trucks.com/forums/1...l#post12664545
Old Jul 11, 2014 | 12:01 AM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I remember Ax talking about tongue oil I think, but Joe is looking it up for you. Its good to see your name pop up. So I wanted to say hello.
Old Jul 11, 2014 | 12:15 AM
PHXHawk's Avatar
PHXHawk
The PO put teak in the bed of mine. I don't know how long its been there but it looks good. I just brush on some teak oil every year. If it's good for boats it should hold up outdoors.
Old Jul 11, 2014 | 12:20 AM
arrowheadfred
woosbed
Thanks g. uys yall been very helpfull when I ever get the inter. net back ill be back on board
Old Jul 11, 2014 | 06:42 AM
carnut122's Avatar
carnut122
Hey dale,
You ever get your cabin finished? How's the fishing? I was wondering what happened to you. I used Por Pelucid with spar urethane on top of it for UV protection. However, my truck is a garage queen, so you probably should take other's advice. I put mine on per Mar-K's tests:
http://www.mar-k.com/wood_finish_testing_ii.aspx
Old Jul 11, 2014 | 09:30 AM
GB SISSON's Avatar
GB SISSON
I'll go along with PXH. I tried to post a one word reply yesterday and it was 'teak'. They claim the teak decks on the Titanic are still as good as new! King of the outdoor woods, but VERY spendy. Your truck looks worthy of it though.
Old Jul 11, 2014 | 01:22 PM
mwarner1948's Avatar
mwarner1948
Talking
Here's my 2bits...I would use Teak Oil. I have owned wooden boats for most of my life and I can say that if you properly seal the wood, use Benite sealer, then apply multiple coats of teak oil you will be OK. I have used this system in my house on Fir doors and Alder baseboards and it lasts. (Not to mention teak decks on the boats.) You can get an almost varnish like finish with about 6 coats of oil and you only have to lightly clean the wood and add one coat every year to keep it looking great. Application is easy as you don't have the same problems with runs that you have with varnish. I never liked the Poly varnish substitutes as it lifts from the wood after a time when left outside. I'm about to do the wood on my '51 F-2 and I will be using this system to keep it bright.
Good Luck,
Superdutyintendent
Nov 23, 2011 01:29 PM
FORDSDOWNER
Jan 3, 2008 07:22 PM
Fomoko1
Canadian National Chapter
Sep 15, 2007 07:13 PM
1964 4x4
Oil & Lubrication
Sep 9, 2006 11:40 AM
