Oil & Lubrication
Oil additives
Old Sep 5, 2006 | 06:58 PM
1964 4x4's Avatar
1964 4x4
Oil additives
If all the oil additives are bogus, Then why would Shelby stand behind a product called Zmax?.
Old Sep 5, 2006 | 09:56 PM
rusty70f100's Avatar
rusty70f100
Because he's making money off of it, maybe?
Old Sep 5, 2006 | 10:44 PM
Flash's Avatar
Flash
Not ALL after market additives are bogus, just 99.9%. Just like this one:
http://www.ftc.gov/os/caselist/00232...tip0023256.pdf
I guess W C Fields was right, there is a sucker on every corner.
Old Sep 6, 2006 | 08:16 AM
pawpaw's Avatar
pawpaw
Could be he endorced this product before he read these postings!!!!!
http://nephtune.spacebears.com/cars/legal/index
Old Sep 6, 2006 | 12:11 PM
pawpaw's Avatar
pawpaw
Above URL Link Correction
Dang I can't spell & messed up the link, did an edit & messed that up, then ran out of time before I woke up to all of it!!!! Gettin old s a bummer sometimes.
Anyway here goes again, http://neptune.spacebears.com/cars/legal/index.html
Old Sep 6, 2006 | 08:43 PM
bruce381's Avatar
bruce381
Most additives are whats in a motor oil anyway so they will not hurt a thing just not needed and or will do nothing.
bruce
Old Sep 7, 2006 | 09:12 AM
pawpaw's Avatar
pawpaw
Seeing as how Z-Max doesn't meet ANY lube spec, much less any of Fords requirements & since we don't know whats in it, in what form, or in what concentration, or for that matter, any other aftermarket snake oil's brew, think I'd just opt to leave all of them on the shelf, with all due respect to Mr Shelby, Bill Dance, Unser & can't remember the rest of the long list of folks that have lent their names to this snake oil over the years.
Our oils add pack, has been carefully chosen, balanced, blended, TESTED, then CERTIFIED, that it's STABLE & it'll work as advertised & stand up to certain controlled conditions, by lube engineers who spend a lifetime at their profession.
So who do we think we are, to begin second guessing them, about whats best for our crankcase??????
The base oil/s & it's add pack are carefully chosen, balanced & blended, to be synergistic, such that the sum total, is greater than the sum of the individuals.
So if we come along, though well meaning & wanting to do something nice for our engines & dump some unkown brew into our crankase, seems to me the best we could hope for, is that it'll do no harm!!!!!
I mean if we dump some unknown chemical cocktail into our oil sump, we have no idea what's going to happen chemically, or with temperature.
We have no idea where the base oils saturation point is, for a particular additive, or even IF what we've just added, will even mix with the particular base oil & it's add pack, thats in our crankcase.
Thats right, some oils, especially synthetic oils, don't like, or won't accept some addtives & require a "carrier" oil to blend a particular additive in & then you can't add but so much, then it'll percipitate out, or cause some other unwanted result.
Some oils may be close to, or at their saturation point for a particular addtive & the extra additive we've just dumped in may push it over the top & cause that additive to percipitate out of solution & do who knows what in the engine, or it may cause some other unwanted reaction or result.
Other additives won't work together, or with a particular base oil. Or wll only work together in certain concentrations.
SO, having said all that, I don't know why we continue to fall for all these "Snake Oil" adds, or just dismiss them lightly.
Why would we suppose, some unkown business, or some person, would know more, or have some secret brew, that a additive manufacturer & lube enginer in a multi million dollar facility, spending a lifetime studying additives & formulations, doesn't alrady know about?????
There is nothing "special" in Z-Max, or any other snake oil!!!!!
Their goal is to create doubt in our minds. To cause us to believe our oil manufacturer was so cheep, he left out the very thing we need for our lube job, or they know some secret no one else knows & they are the only ones that can provide it in their product.
Go to the link I posted above & scroll down trough the Govt's litigated results, of all the witches brew of additives, including Z-Max, (close to the bottom), & a few bolt on hoaxes too!!!!!
The govt has taken many of them to court & challenged them to prove their advertized claims. Guess who won!!!!!
I suppose one could surmise, ignorance is bliss!!!!! lol
Old Sep 8, 2006 | 11:35 PM
Ed's Avatar
Ed
Smile
Kurt, when you say something like that, you are not writing it correctly. If I might be of some assistance to you, you should have said:
"Because he's making 3off of it, maybe?"
1964 4X4, is at least asking a question, and I give him credit for that. However, 1964 4X4, all quality, certified oil has the correct amount of additives blended with base stocks, as needed. My only excpetion, is if you have a worn, loose, oil burner engine. In that case, using a heavier SAE API oil, would be your best course of action. Use a quality oil, and follow OCI's with a new oil filter at every change.
Old Sep 8, 2006 | 11:38 PM
Ed's Avatar
Ed
Oh brother! Don't know why it said that? My post should have said:
"Because He's Making BBBIIIIIGGGGGGG BIG $$$ off of it, maybe?"
sorry, Ed
Old Sep 9, 2006 | 11:40 AM
rusty70f100
Come on now, I didn't want to be THAT obvious!
beartracks
Jan 28, 2017 07:06 PM
sir alpha
Oil & Lubrication
Jul 2, 2007 10:21 AM
FERacing66
Oil & Lubrication
Mar 15, 2004 08:26 PM
MrBSS
Oil & Lubrication
Nov 11, 2002 10:40 AM
laka
Oil & Lubrication
Jun 2, 2001 09:16 PM
