"How-To" Install bedsides
Old Jan 12, 2015 | 05:19 PM
  #46
HD's Avatar
HD
That is an absolutely amazing looking truck. You do wonderful work.
What is the name of the glue you used and where did you buy it? Are you still satisfied with it after a few months?
I'm thinking of going this route for a couple repairs myself.
Thanks!
Old Jan 12, 2015 | 05:41 PM
  #47
Diesel_Brad's Avatar
Diesel_Brad
Norton or 3m both sell panel adhesive
Old Jan 14, 2015 | 10:28 PM
  #48
FordxFour's Avatar
FordxFour
Great Job!!! Thanks for sharing this.
Old Oct 20, 2017 | 03:50 AM
  #49
Skip1970's Avatar
Skip1970
where you get them steps on the crew cab/
Old Oct 21, 2017 | 07:52 AM
  #50
Diesel_Brad
DeeZee tough steps but they have been obsoleted
Old Oct 21, 2017 | 12:24 PM
  #51
Roger T. Pipe's Avatar
Roger T. Pipe
It seems as tough every decent step-up for our OBS trucks are long gone, man I wish someone would make something decent that doesn't require you to bolt thru the rockers....
Old Oct 21, 2017 | 03:37 PM
  #52
Skip1970's Avatar
Skip1970
i guess it wouldnt be to hard to construct, but them ones do look nice.
Old Dec 9, 2017 | 12:12 AM
  #53
McLeod's Avatar
McLeod
You do some amazing work!
There is something that bothers me every time I fill up at gas station that maybe you know the answer to.
The bushing for my OEM gas cap tether has disintegrated and every one at the wrecking yard is just as bad.
Have you found a source to replace this bushing to keep the originality?
Old Dec 9, 2017 | 06:08 AM
  #54
mrollings53's Avatar
mrollings53
Ditto, I looked at replacing my caps because the rear decided to fall apart like the front already had. Parts house didn't have anything with a tether, or keyed alike locking caps.
Old Dec 9, 2017 | 06:32 AM
  #55
Diesel_Brad
I do away with the tether on every truck I own. All it does is promote scratches. If you cant remember your gas cap, them maybe you shouldn't be driving
Old Dec 9, 2017 | 09:09 AM
  #56
Fastback460's Avatar
Fastback460
I did the same with mine. A month after getting my truck painted I found a scratch from the cap, and I cut them both off 5 minutes later.
Old Dec 9, 2017 | 06:56 PM
  #57
McLeod's Avatar
McLeod
Old Sep 12, 2021 | 12:37 PM
  #58
Joe86F150's Avatar
Joe86F150
Inner wheel liner
I been asked many times what is involved with replacing bed sides. So I figured I would do a step by step procedure an show what all is involved. I live in the North East and my trucks get driven in all weather conditions so I go the EXTRA MILE to make sure the repair lasts a LONG TIME. I may be going overboard for the southern guys, but If you live anywhere near salt and plan on keeping the truck for any amount of time, I HIGHLY recommend doing doing exactly this.
1st.
Take the bed off the truck(unhook wiring, fuel fillers and 6 bolts holding the bed down. Remove exhaust shields from the underside of the bed and set on a stable level set of horses.
2nd.
Find the spot welds that hold the skins on to the bed. There are A LOT approx 80 spot welds on a short bed. You will need a 1/8" bit and 3/8" spot weld bit.(inner lip{30}, wheel well{15}, front edge of bed{15}, rear tailgate opening{15}), small lip under tail light{5})
Spot weld bit
3rd.
Drill into the center of each spot weld with the 1/8" bit, but do NOT drill all the way thru. Just make a dimple for the centering bit of the spot bit to stay in place.
4th.
After putting the dimple in each weld, use the Spot drill to "cut out" each spot weld. Again, you do NOT want to go all the way thru. Just thru the outer skin, NOT the inner structure.
5th.
You need a body chisel to cut thru the remainder of the weld. You just get between the panel and hammer it thru the weld. If you have to hammer really hard, you did not drill out the spot weld correctly. If you did, the chisel will cut right thru. Once all the welds are cut, you can remove the side. Same procedure for each side.
(NOTE, mine has the huge well well opening because I converted my try to a dually)
6th.
Now this is my perogative but again, I drive in the elements and I want it to last I sandblast the ENTIRE underside of the bed, The inner wheel well arches and associated hardware(note drain holes added to the inner arches to allow for drainage AND accessibility to clean. I remove the arch completely to do a better job of cleaning and painting)
Starting this project myself and I’m Currious how the inner wheel liner is installed? Thanks for the help.
Old Sep 21, 2021 | 04:42 PM
  #59
Diesel_Brad
Also bonded on with panel bond.
I clamp the outer edge and use self taping screws to hold it to the inner bed wheel well. Once the adhesive is setup, the clamps and crews are removed. The burs are touched up with a grinder and the screw holes are filled with panel bond
Diesel_Brad
Ford Truck Parts for Sale
Jan 25, 2015 12:26 PM
Black79
34
Jan 23, 2014 06:43 PM
Custom49
Jan 19, 2014 09:53 PM
fordka
25
Feb 27, 2013 04:22 PM
