"How-To" Install bedsides
Old Jul 14, 2014 | 04:43 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by The other Joe
Brad,
That looks great. Nice work.
Are you going to glue the panels on or weld them?
Thanks,
Joe W
Everything is going to be glued. No welding here
Old Jul 14, 2014 | 07:53 PM
broozerthehoundog's Avatar
broozerthehoundog
panel source?
Where did you source the panels? Lmc, Ford?
Thanks
Jim
Originally Posted by Diesel_Brad
If I didn't have to sandblast the bed liner off the bottom side of the bed.....
1 hour to remove bed
2.5 hours to remove both sides
2 hour to sandblast underside of bed
2 hours to POR and paint bottom side of bed
2 hour to prep bed sides
1 hour to prime & paint bed sides
___________
10.5 so far
Material
$406 drivers side skin
$438 passenger side skin
$38 1 qt POR15
$106 for 3 quarts of epoxy prime and hardener
$47 for gallon of chassis black
$68 for 2 quarts of color
$130 for gallon of clear w hardener
$36 for 300lbs of sand
_____________________________
$1269 so far
Old Jul 14, 2014 | 07:56 PM
Bob Gervais's Avatar
Bob Gervais
Nice work, as usual!
Brad, should the same process be used for new fenders, radiator supports, and welded in repair areas? Scuff the e-coat, followed by epoxy primer? On the interior surfaces of your bedsides, where they're epoxy primed, are you planning on putting a topcoat over the primer?
Old Jul 15, 2014 | 04:44 AM
Diesel_Brad
Thanks
Jim
NOT LMC. I REFUSE to buy their JUNK
I tried to get them from Ford, but there was one ONE In the country and it was in Alaska. Don't forget, Ford was quite a bit more. Like about 1000 for one and 1200 for the other.
I went thru NPD for the sides and Jeffs Bronco Graveyard for the inner arches
Yes. The e-coat is NOT a moisture barrier. So once wet, it does not take long for rust to start.
As for the inside of my bed skins, after prime they got painted with chassis black. It is not for looks, but to match the rest of the underside of the truck(was all sandblasted, POR15 then top coated with tractor black) but add another layer of protective material
Old Jul 15, 2014 | 05:23 AM
Bob Gervais
Got it. Thanks Brad.
Old Jul 15, 2014 | 07:07 AM
Fastback460's Avatar
Fastback460
Looks good, once again you did another great job.
But I do have a question about the POR15. I'm planning on coating my frame, the underside of my bed, and the bedsides while they are being replaced at my cousins body shop with POR15 this year, do you ever use the "Prep & Ready" that they recommend? Or is it not needed?
Old Jul 15, 2014 | 09:08 PM
Diesel_Brad
Marine clean and Prep & ready are for non sandblasted rusted metal. SO I never use it since I ALWAYS sandblast before I use POR.
Just remember, POR doe NOT go over painted surfaces, ONLY rusted or sandblasted surfaces
Old Jul 15, 2014 | 09:14 PM
Diesel_Brad
Got some more done tonight. Not as much as I wanted but some.
Prepped the entire bed for both sides. Also prepped one side and fitted it. Then glued it on. I ended up using 31 vise grips and about 10 screws for the impossible to reach spots.
Remember. I cleaned every surface where the panel boning adhesive was to go, to BARE metal. i also made sure it was course(36 grit if possible)
I put the glue on BOTH pieces to be bonded then level it out with my finger(covered in latex glove). That makes sure there is NO BARE METAL
It will set up and tomorrow if I have time I will unclamp it
Old Jul 15, 2014 | 11:11 PM
junkkingranch's Avatar
junkkingranch
Brad - nice work as always. Looks great. Great write up on doing bedsides. Do you put any of the lower braces in at this stage to help fit or steady anything? Also when your fitting it how do you mark it so that it glues on in the exact same position it fit into?
Thanks
Jeremy
Old Jul 16, 2014 | 04:42 AM
Diesel_Brad
Thanks
Jeremy
Yes, I did not show it, but YES the braces are attached.
Also, IF you inner arches are still in, you bond these at the same time
Old Jul 16, 2014 | 08:19 AM
joegeds's Avatar
joegeds
I haven't worked with POR15 yet, but I stopped into a Sherwin Williams automotive paint supply store here in the area to find out if they sell the POR15. They do, and I asked about the kit. He said the only thing you really need to do before applying the POR15 is to make sure it is clean and degreased. So a degreaser is a must (he said it doesn't have to be Marine Clean, but could be another product to save some $$$) , but he said the metal ready is not really necessary.
Having said that, I currently am using the POR15 just to refinish an old engine crane I picked up, so to me, it's not as important. When I do take care of my wheel arches on the truck, I'll be following POR15's exact instructions and recommendations - which means using the prep and ready if it says to.
Old Jul 16, 2014 | 01:17 PM
The other Joe's Avatar
The other Joe
Nice work Brad.
I wish I had your energy. You get a lot done. I'm old and slow.
What's the working time on that glue. It must take some time to set all the clamps and screws.
Thanks,
Joe W.
Old Jul 16, 2014 | 04:44 PM
  #28
Diesel_Brad
The working time on the glue I used on this was 75min.
But they also make a 5 and 15 min glue too.
I am guessing with the humidity, the glue is taking longer to cure. I will let it sit clamped another 24hours
Old Aug 16, 2014 | 08:07 PM
  #29
Diesel_Brad
Long over due update
The bed skins had a couple small dings in them, nothing big at all. I think I used a Golf ball size about of body filler. Then laid down some 2k primer. In the one pic, you can see the clamps still holding the one inner arch in place after gluing
then west sanded
White
White taped off and and silver sprayed
Untaped getting ready for clear
3 coats of clear And bugs
Wet sanded and buffed. Still need final polishing
Old Aug 16, 2014 | 11:02 PM
  #30
krooser's Avatar
krooser
Looks good… I'm a firm believer in POR-15 and have used it many times. Good stuff.
