1st time poster.
I may have originally made this post in the wrong forum - sorry.
I work for Fish & Wildlife and we have a 1973 Ford 1ton flatbed, 390 V8 with a single set of points, single vacuum advance distributor. The distributor # is: D3TF 12127 HA. This distributor is not widely listed
The flatbed died about 2 weeks ago, so I started diagnostics when I returned from vacation. Long story short - no spark. The distributor breaker plate is shot, which will run about $25 to replace. I have ready to install new distributor cap, rotor, points, condensor, plugs and wires.
Is there another electronic conversion kit that would be better recommended and would I require anything else to get this set up running, such as a hotter coil???
Go with a Pertronix Ignitor.. it's been on the market for over 20 years so they have lots of street cred to back up their product line.
I have them installed in all my toys but one (a 71 F250 acquired in early May) with not a single failure or issue. The oldest is in my 65 Mustang from... 1989. Bulletproof IMO.
yes you would have to change the plate as any after market conversion mounts to the breaker plate. you can replace it with a stock ford electronic dist. but is not as easy as a pertronics conversion.
The Pertronix kit (I also highly recommend) mounts to the breaker plate in place of the original points. If you breaker plate is broken or detached, it will need to be replaced, but breaker plates are cheap and easily available. All that would be much easier than changing out the distributor completely.
I wouldn't jump the gun on replacing the entire distributor. Breaker plates can pop in half pretty easily; that alone isn't necessarily a sign of the rest of the distributor's condition.
That has always been a problem with the Autolte/Motorcraft distributors.
The breaker plate is actually two pieces, one is fixed, the other pivots to allow movement for the vacuum advance. The two pieces are held together with a plastic rivet. The rivet breaks, which is real common, and the breaker plate can move all over the place. This throws the point or reluctor gap out of adjustment. It will also throw the timing out.
The distributor is usually still in good shape, just the breaker plate needs to be replaced.
Pertronix .
