camber issue with 1979 kingpin dana 60
hey guys! currently driving my 68 highboy with a 79 high pinion king pin axle up front. i have bad positive camber, wearing out the outsides of the tires badly. the axle was rebuilt before i bought it, so im unsure of whats goin on with it. what are some common fixes for this problem? im looking for answers in a bunch of places but coming up empty. please steer me in the right direction!
You can get these in variety of camber degree correction rock auto carries them ..
Camber alignment shim
Also Moog makes this
My 79 F150 4x4 Dana 44 suffers from the same positive camber issue, even with new ball joints. I found shims are made to correct this, they are tapered and fit between the knuckle and the spindle. A Google image search for "Dana 60 camber shims" will give you and idea. Seems to be more options for the 44 than the 60 however.
on
I have used the Moog K992 adjusters. It seemed like every time I looked at the truck, they had loosened themselves up and I had a bunch of negative camber and toe.
They were torqued to spec but still had problems.
My opinion is the only way I would run them is to re-torque at every oil change. That -might- be often enough.
I ended up using another brand that uses a positive pin index hole but I forget the brand name.
So far, so good.
So far, so good.
1980302windsor
12-05-2010 07:20 AM
Christopher2
04-15-2005 10:05 AM
mckdaddyfrd
01-23-2004 01:03 AM
