Major alignment problem
Old Jan 28, 2007 | 10:26 PM
jnye6625's Avatar
jnye6625
I have a 1995 F-250 with a front Dana 60 solid axle with kingpins from a 1990 F-350. The drivers side has positive camber, and the passenger side has negative camber. Is it possible to adjust the camber on an axle like this with kingpins? What could be causing the camber issues? Could it be worn out kingpins?
Old Jan 29, 2007 | 10:59 AM
jnye6625's Avatar
jnye6625
Any ideas? Could kingpin bushings have anything to do with this? Is there a way to check "C" on the end of the tube to make sure that the tube isnt bent?
Old Jan 29, 2007 | 11:33 AM
bohiaa's Avatar
bohiaa
take it to a shop like goodyear and have them look at it
most of the time it dont cost anything and they will tell ya what's wrong
Old Jan 29, 2007 | 11:34 AM
dgeesaman's Avatar
dgeesaman
Nevermind, I see it's a solid axle. Good luck.
