Multiple Dianostic Code Trouble
Old Jun 23, 2014 | 10:25 PM
jamiej780's Avatar
jamiej780
I have 4 codes that have went off on my 2007 6.0 Powerstroke and really do not know where to start. The codes seem to be related and I believe that the EP Sensor is plugged/faulty and this may be causing the other codes to be activated. The codes are as follows:
P0480--Cooling Fan circuit not responding or faulty fan relay
P0470--ECM has detected a signal error from the EP Sensor or faulty EP Sensor
Now in regards to these two codes that are listed, I am frightened that I have a fuel injector out on Cylinder 5 and that my FICM needs to be reflashed/replaced.
P0611--ECM has not received a signal from the fuel injector interface module
P0273--Cylinder 5 injector circuit low. ECM has detected a fault in the fuel injection circuit
Can someone lead me in the right direction as to where to start diagnosing, so I am not running circles. The truck runs fine and doesn't act as if an injector is missing, however it can be low on power sometimes.
Old Jun 23, 2014 | 11:12 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
P0611 is the death sentence for the FICM
P0470 faulty sensor or chafed harness
P0480 inspect the fan connector
Josh
Old Jun 23, 2014 | 11:30 PM
jamiej780's Avatar
jamiej780
So in your opinion then I regards to the FICM I do believe it is the 4 pin model and I will test it with my volt meter. However, I was told by a ford tech that I could jus replace half of the FICM and now have to have any computer programming done. Now with that being said I guess I am questioning whether or not to replace the whole FICM or if I would be ok with just replacing the 1/2 part of it.
Now in regards to the EP sensor. Should I go on ahead and install my EGR delete kit and 4" exhaust? Then if I make these modifications will it eliminate that EP sensor then I won't have to worry about it or would that be a waste of money?
Finally I will diagnose the wiring harness to the fan clutch and the fan relay to eliminate that problem. However, I have a feeling that code is being set off due to the EP sensor failure. Any thoughts?
Old Jun 23, 2014 | 11:36 PM
Bullitt390's Avatar
Bullitt390
The EBP sensor is used my the 07 PCM, it's possible the sensor and tube are gummed, but I suspect it's electrical.
For any FICM related issues I recommend FICM Repair.com - Your Source for FICM Repair as replacing with a Ford half-shell, or even a power supply from Dorman would be considered temporary, at best.
Josh
Old Jun 24, 2014 | 01:40 AM
Yahiko's Avatar
Yahiko
Also if you have Ed at Ficmrepair.com do the repair you don't
have to program anything or pay Ford to program the PCM & FICM.
Also when you only do the FICM 1/2 shell you don't have to
do ANY programming at all. keep the money in YOUR pocket.
Sean
Old Jun 24, 2014 | 03:19 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
If you send the FICM on into us, we could also review the health of the logic board instead of just being stuck assuming that 100% of the modules' issue is related to the amplifier side. We could also of course pop in an aftermarket tune on your module to give you a reason to stop lusting after the 6.7's...
Old Jun 24, 2014 | 04:01 PM
raptor131's Avatar
raptor131
How do you and mark know when something is posted related to your expertise. It is scary! Have you guys teamed up with google?
Old Jun 24, 2014 | 06:40 PM
cheezit's Avatar
cheezit
Its very odd but I have seen a bad ficm set ebp codes. Start with ficm diag then clear codes, retest.
You may still have more then one issue, the fan or connector is suspect as a second issue.
Old Jun 25, 2014 | 08:25 AM
FICMrepair.com
Former Vendor
Pay no attention to the man behind the curtain...
Old Jun 25, 2014 | 02:48 PM
Yahiko's Avatar
Yahiko
I asked Mark Kovalsky about that once.
I think that he "KNOWS" when the word Transmission is said in a post.
Something must go "Ding" on his computer.
I have an idea how it could be done and am not going to tell.
So it will remain a mystery I feel.
Sean
Special Ed
Oct 5, 2011 09:12 AM
6speed_whistler
Jul 20, 2011 12:38 PM
rado
Jul 1, 2011 09:55 AM
Racecarhauler
May 16, 2010 06:15 PM
RangerRuss
1983 - 2012 Ranger & B-Series
Sep 23, 2004 11:01 AM
