Edge codes?!
Old Jun 30, 2011 | 04:09 AM
rado's Avatar
rado
Edge codes?!
Edge Evolution gave the following error codes:
P0480: Cooling Fan 1 Ctrl Circ Error
P0520: Fan Speed ​​Sebsor Circ No Signal
P2285: Injector Ctrl Press Sensor Circ Low
What are these meinaa and can affect a visit to unevenness in the cold?
Today FICM demolished and the wiring checked (OK)
2004 6.0 Power Stroke was the vehicle
Old Jun 30, 2011 | 04:56 AM
npccpartsman's Avatar
npccpartsman
P0480 and P0520--check the fan clutch connector wires between the engine and fan shroud for broken/cut wires.
P2285--Is your ICP sensor under the turbo (03 motor) or on the passenger side valve cover (04 motor) The code indicates a circuit code but if the sensor is under the turbo the code usually means the sensor is toast. Check the sensor plug-in and see if it's oil soaked. If it is then replace sensor and pigtail/plug-in
Old Jul 1, 2011 | 01:56 AM
rado's Avatar
rado
Add tags this morning:
P0401: Exhaust Gas Recirculation Flow Detected Insuff
P0299: T / S Charger Underboost
Is the charger to be in need of renewal, or broken?
The car is fitted with EGR delete kit, but what that error means the EGF?
Thanks again guys
Old Jul 1, 2011 | 09:55 AM
texans's Avatar
texans
If you have an egr delete there is nothing you can really do about the egr code. Turbo underboost could be a few things. Try clearing that code and see if it comes back. As for the other codes npccpartsman is right. Check the fan clutch wireing for a cut wire. The ICP code could just be a one time instance as well. I would clear that, and see if it comes back.
Tysoid3317
Aug 15, 2012 02:48 PM
StumpJumper00
21
Feb 14, 2012 06:45 PM
TXtinct
17
Nov 3, 2011 10:21 AM
ford7379trucks
Jan 22, 2011 05:34 PM
Jeremy2792
Mar 23, 2009 12:19 PM
