Intermediate Steering Shaft - Hard Steering
Old Jun 21, 2014 | 11:39 PM
oldman1's Avatar
oldman1
Replaced the Intermediate Steering Shaft at 114,000 miles. Symptoms felt like power steering going out but no pump noise or low fluid. Steering became hard to turn and it sometimes felt like a tie rod was letting go.
Temporary resolution was to spray the two steering shaft joints with penetrating oil (PB Blaster). That freed them up pretty well. Then I ordered Dorman part 425361 (425-361) $127 from Rock Auto. Simple enough job. Lots of good vids on YouTube.
I don’t recommend spraying the steering shaft joints as preventative maintenance. Penetrating oil will get into the needle bearings and break down the bearing grease. That will cause the joints to fail over time.
Two side benefits, the truck steering is much smoother and small road bumps and potholes are much less noticeable. Feels like it was when new.
Old Jun 22, 2014 | 06:04 AM
60DRB's Avatar
60DRB
Glad it's repaired. My B-I-L had an issue with steering shaft noise and I used a litium grease sprayed into the joint/bearing area which seemed to solve the problem. Hmmm. I hope the lube spray doesn't do like the PB Blaster did yours.
Old Jun 23, 2014 | 06:24 AM
RangerFL1's Avatar
RangerFL1
Thanks for sharing your experience
Old Jun 24, 2014 | 02:26 PM
1saxman's Avatar
1saxman
The solvent in spray White Lithium Grease evaporates quickly but also carries the grease into wherever it penetrates, so you're probably good with that. It just makes a mess, but you can wipe off the excess.
0351mike
1978 - 1996 Big Bronco
Dec 3, 2017 04:47 PM
baileyj
2004 - 2008 F150
Oct 19, 2014 08:24 AM
Skoony
2004 - 2008 F150
Oct 17, 2013 08:08 PM
Its no M3A3
Dec 27, 2006 08:24 PM
Avanti
Bronco II
Apr 4, 2005 10:20 PM
