Steering problem
Old Oct 8, 2013 | 04:20 PM
Skoony's Avatar
Skoony
Steering problem
If any one runs into a problem with your steering wheel not wanting to return back to straight after a turn...spray wd40 on u joints on steering shaft ( under hood)
Old Oct 17, 2013 | 06:45 AM
04fxdwgi's Avatar
04fxdwgi
Spraying w/ WD40 will just loosen them up temporarily. I had to do the spray, every 3 months or so, since it kept re-occuring.
I smartened up and pulled the shaft out of my '04, loosened them up, then got a grease gun needle adapter, snuck it under the rubber boots on the u-joints and pumped teflon bearing grease into the bearings. Did that about 3 years ago and no problems since.
Old Oct 17, 2013 | 08:08 PM
Skoony's Avatar
Skoony
Steering problem
Nice thanx for the tip...i may try this if it comes back
0351mike
1978 - 1996 Big Bronco
Dec 3, 2017 04:47 PM
pbsmith
Dec 15, 2015 11:42 AM
oldman1
2004 - 2008 F150
Jun 24, 2014 02:26 PM
vibrancy
Feb 6, 2010 10:10 PM
RangerGlenn
1983 - 2012 Ranger & B-Series
Feb 25, 2004 09:45 PM
