Front diff seal
Old Jun 24, 2014 | 05:37 PM
Hendog's Avatar
Hendog
Front diff seal
My front differential is leaking. Are there any special Ford tools required to replace the seal? Or is it simply bolt (and fluid) removal, seal replacement, fill with new fluid. Any tips or heads-up on this?
Thank you
Old Jun 24, 2014 | 05:46 PM
sosotwo's Avatar
sosotwo
are u talking axle seal?
i just did one on a 05. straight forward remove cover remove clip on axle,
remove cv shaft. if it is on pass side remove axle housing after you slide axle out part way.
took about 2 hours to do
good luck
tom
Old Jun 24, 2014 | 07:59 PM
Hendog's Avatar
Hendog
To be honest, I'm not sure where the leak is coming from; I thought it was just from the diff cover. To be sure I guess I should clean it up and then see where the leak is coming from...
maximusfd
Dec 10, 2013 09:28 AM
jim20j
Escape & Escape Hybrid
Jul 3, 2012 01:19 PM
ztodd377
May 16, 2011 11:08 PM
gvrangr98
1983 - 2012 Ranger & B-Series
Sep 12, 2008 03:45 PM
Shawn2001EXP
Apr 12, 2006 07:23 AM
