Parking/emergency brake doesnt hold
on
I've kinda been thinking about this one for a while. The parking brake on my truck doesn't hold worth a damn. No resistance at all really. I've had the rear brakes apart a couple times, everything looked good and was hooked up. The cables are hooked up and they do get pulled when I depress the pedal. But still no braking force is generated. I have the rear brakes adjusted out pretty well.
So, can someone maybe explain the operation of the parking brake and if there's an adjustment that can be made?
I don't hardly ever need the brake, but it would be nice to have in certain situations.
Just to make sure the rear shoes are properly adjusted. If they are not adjusted out properly the parking brake cable has to pull farther to get them to actuate. These cables have lots of years and stretching on them. I had to adjust mine quite a bit after adjusting the rear brakes to get it to hold properly.
on
I had a similar experience with aftermarket parking brake cables (The ones that are covered in rubber and sold by the parts stores). It didn't matter how much I adjusted the brake shoes or parking brake cables they just wouldn't hold very well. I ended up finding some NOS cables and installing them instead--the parking brake worked much better. I suspected that the wire coil housing inside the rubber covering used on the after market ones would compress or maybe squirm around more and not keep the proper tension on the cables. What kind of cables are on your truck?
on
Oh yes hard & fast until pedal comes up.
Guys who don't read books pull off the self adjusters
not knowing how they work! hello
This ***** the shoes just enough to trip the self adjuster for one click at a time.
So if pedal is pretty low it will take some repeated of backing and pump hard for each click for the adjust to build up the pedal.. Now that you got it the know how.
Orich
Orich
RyanMiller
08-23-2004 08:15 PM
