Coolant Filter question
Old Jun 18, 2014 | 06:31 PM
VQT's Avatar
VQT
Does the coolant filters list below are the only filter to be used for our truck? I found a guy that will sell me the Fleetguard WF-2054 for $1 a filter and he has 10 of them. Thanks,
Fleetguard WF-2077
Baldwin B5134
Baldwin B5089 (shorter)
John Deere RE11992
Caterpillar 9Y4528
Cummins 3300721
Wix 24070
NAPA 4070
NAPA 4069 (one inch shorter)
AC-Delco WF-108
Fram PR3383
Donaldson P554685
Alliance (Freightliner) WF2077
CarQuest 89070
Hasting WC8
Purolator W54451
Old Jun 18, 2014 | 08:13 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Looks like the WF-2054 has an SCA (additive). Definitely don't use it if you have the EC-1 coolant (red color). Maybe OK with Ford Gold coolant? Seems a little small in diameter. Threads sound about right.
Chemical Additive: DCA2 (MODIFIED)
Overall Height: 137.16 mm (5.4 in)
Largest OD: 94.49 mm (3.72 in)
Thread Size: 11/16-16 UN-2B
You can get one on Amazon for $215.99 (lol, I think that's a typo or something)
Amazon.com: Fleetguard WF2054 - WATER FILTER: Automotive Amazon.com: Fleetguard WF2054 - WATER FILTER: Automotive
Old Jun 18, 2014 | 08:20 PM
diesel_dan's Avatar
diesel_dan
I saw the additive too, but wasn't sure what DCA (modified) was. I googled the filter and saw a Chinese place that's doing knock-offs for a buck a piece if you order at least 20.
1st Q for me was: what filter system (base) do you have?
Old Jun 18, 2014 | 08:27 PM
Rusty Axlerod
Didn't mean to get all complicated with the answer. I'd just use one from the list and skip this one.
Old Jun 18, 2014 | 08:30 PM
diesel_dan's Avatar
diesel_dan
So waaaay true. Don't need to change 'em often and can always find a decent price on the non-SCA ones...
Why do I over-complicate things?! Go ahead and answer, my Wife would like to know....
Old Jun 18, 2014 | 10:08 PM
VQT's Avatar
VQT
I am using the DieselSite filter kit, and Delo Coolant CAT - EC 1 red color. This WF 2054 is made in the USA, I don't see the additive you guy mention from Amazon or on the body of the filter itself.
Too bad this won't work since it is so cheap. I am paying for the Baldwin B5134 and Donaldson P554685 for about $10 each.
Old Jun 18, 2014 | 10:09 PM
VQT's Avatar
VQT
Okay Rusty.
Old Jun 19, 2014 | 01:02 AM
diesel_dan's Avatar
diesel_dan
I just googled the filter brand/number and found a number of hits on the additive...
Curious as to what routine you use to change them out? Time, Miles, outlet going cool? Have you opened up any to see what you are collecting?
This is no jab, just wondering what some folks are basing their coolant filter changing on. I personally am not going with what has been recommended (change the 1st one at 500 miles, next at 6 months, etc.). They are big filters and can hold lots of particulate matter in the media before losing even a little flow, but that is my opinion, so take it for what it's worth (not much)...
Old Jun 19, 2014 | 09:44 AM
VQT's Avatar
VQT
Dan,
I changed the first one after about 1000 miles, 2 nd one about 3000 miles, 3 rd at about 5- 6K, 4th about 10K. It is currently on the 5th filter. The oil cooler and EGR cooler were change about 20K miles ago. Truck currently at ~164K miles. I have not cut up any of the filter to see the inside.
I don't drive this daily, just for long trips at about every 3-4 months I drive on average of 1,500 miles to 4,000 miles. Drive to work, 60 miles round trip, a few days before each long trips to check out the engine condition. Last year a few days before Thanksgiving, injector #6 die on me. Ended up change the injector and clean all the spool and O-Rings of the remaing driver side injectors, including the nipple cup O-Rings. Haven't touch the passenger side yet since the engine seem to run fine.
Bob_T
Apr 30, 2014 04:31 PM
vectrex
Apr 23, 2012 02:56 PM
Liquid10Rider
Apr 25, 2011 03:00 PM
Jaaaaaaackman
13
Dec 14, 2009 01:15 AM
dapgar
Mar 5, 2007 09:13 AM
