Turbo Whistle
Old Jul 29, 2009 | 12:33 PM
PsD007.3's Avatar
PsD007.3
Turbo Whistle
soo i noticed my dads 99.5 whistles louder than my 2000 at an idle..we got the same exhaust the only thing we have different if i have the age stage 2 and he has a stock set up, soo why does his whistle louder?? i think i might have a boost leak somewhere due to smelling diesel fumes in the cab every once in a while..any idea's? why his would bw louder whistle?? maybe i do have a boost leak??
Old Jul 29, 2009 | 12:49 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look at your up-pipes for black soot at the connections. If you are smelling fumes in the cab, that is a likely place for an exhaust leak.
Old Jul 29, 2009 | 12:53 PM
PsD007.3's Avatar
PsD007.3
ok ok, if its a bad leak would it make the turbo not spool up as fast maybe?? therefore not makin it as loud???
Old Jul 29, 2009 | 01:01 PM
miller_feed
Yes, you will not get the wheel turning as fast and will be loosing boost. My turbo whistles pretty loud when I start making boost. Also, every truck with the same mods will not sound the same. Have you looked to see if he has a WW installed?
Old Jul 29, 2009 | 01:05 PM
Robert6401's Avatar
Robert6401
I can't tell you whether or not it is something wrong, but my father-in-law's 2002 seemed to have a louder whistle than my 2003 and his also has the stock air box whereas mine as the 6637. I was kind of surprised when I drove his a couple of months ago, and wondered if the open-air filter had something to do with it.
Old Jul 29, 2009 | 01:07 PM
Robert6401's Avatar
Robert6401
Sorry if this is hijacking, but can someone explain exactly which pipes are the "up-pipes?" Forgive my dumb question.
Old Jul 29, 2009 | 01:36 PM
miller_feed
The up-pipes are the pipes coming off the back of the turbo and go down to both exhaust manifolds. Stand on the drivers side of the engine bay and look behind the turbo and engine. One going down each side.
Old Jul 29, 2009 | 01:38 PM
miller_feed
This is a shot of my bellowed up-pipes before they were installed on my truck.
Old Jul 29, 2009 | 02:13 PM
Kwikkordead's Avatar
Kwikkordead
And here is a shot of the old style donut pipes on an E450 that were leaking so bad that the turbo barely spooled up.
See all the black streaks all over the pipe and the bell housing?
That is loss of exhaust drive pressure, a very bad thing on turbocharged engines.
After I changed them out and the owner drove away, he called me within two minutes and asked me what all that whistling was.
It was his turbo finally doing some work!
Old Jul 29, 2009 | 02:58 PM
HKusp's Avatar
HKusp
The other thing that may be going on here, is the older truck may have an old style "wicked wheel" and the 2000 model doesn't. My fathers 99 really whistled a lot louder than mine until I put the WW on my truck.
Nick9219
17
Sep 12, 2021 11:40 PM
PJ-Hunter
Apr 11, 2016 10:52 AM
waystro
47
Mar 26, 2016 01:47 AM
Willk98k
Dec 18, 2015 08:14 PM
themaniam1
6.4L Power Stroke Diesel
Jul 26, 2014 11:07 PM
