Sponsored by: Real Truck
LED Headlights
Old Jun 23, 2014 | 08:38 AM
  #91
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by AlaskanEx
I'm really really debating now for my new truck, I wont have any place for mounting AUX lighting like my Excursion and i need high beams as when you get 4 hours of sunlight in the middle of winter you need all the light you can get...plus moose are a big concern!
its a toss up i'm 50/50 going LED or HID right now...i have some time to decide.
Neither LED nor HID will provide great high beams. Not for what you need them for anyway. Mooses. Moose? Meese?
You should get some light force lights
Old Jun 23, 2014 | 08:57 AM
  #92
02TB250's Avatar
02TB250
I think mine are pretty good...
Its more the housings fault then the bulb. There's just a lot to be desired with the reflector housing
Old Jun 23, 2014 | 10:14 AM
  #93
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Actually my VVME HIDs have wonderful high beams. I've been running them in various trucks since 2007 with my dads being an original '07 kit working without issue.
Light Forces are cool but i'm happy with my cheap Hellas with 100w bulbs. Like i said though the new F-150 has no place for lights and i don't want to clutter up the sexy front end.
Old Jun 23, 2014 | 11:40 AM
  #94
A/Ox4's Avatar
A/Ox4
9 ECHO 1
This is more what I was referring to than the lights themselves. If you installed projectors however...
That's good then. I've personally never seen HIDs in these trucks do too well because of the reflectors like mentioned above.
Also, the light force was mostly sarcasm. Kinda pricy for my taste. But I hear they are nice
Old Jun 23, 2014 | 11:58 AM
  #95
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I've found with the HIDs the bulbs make a HUGE difference in focus and cutoff. The cheap replacement bulbs do not place the arc of the light in the right place and screw the beam pattern all up. Thus far VVME had had the best bulbs i've found and they keep a stock focus and cutoff, i also never get flashed although i took great care in making sure i had them aimed well.
Light Forces are used A LOT up here as they are a great light, all the trucks running the Dalton Highway (think ice road truckers) have at least a few sets on them. To me the cost is a bit of a hold back, plus my friend had 2 sets of his stolen off his Expedition.
Old Jun 27, 2014 | 08:14 PM
  #96
acf6's Avatar
acf6
still doing good
  #97
acf6's Avatar
acf6
still doing good
Old Jun 27, 2014 | 08:16 PM
  #98
Trophy_23's Avatar
Trophy_23
Looks good! What are the lights you have under the truck?
Old Jun 27, 2014 | 08:18 PM
  #99
acf6's Avatar
acf6
Old Jun 27, 2014 | 08:20 PM
  #100
Trophy_23's Avatar
Trophy_23
What did you mount them on? The forward ones I mean. I already have some on the hitch but sometimes there is a big dark spot beside the truck so I like that idea.
Old Jun 27, 2014 | 08:21 PM
  #101
acf6's Avatar
acf6
Just some factory holes in the frame next to the trans crossmember lol
Old Jun 27, 2014 | 08:23 PM
  #102
Trophy_23's Avatar
Trophy_23
Thanks! I will have a look next time i'm under the truck.
Old Jun 27, 2014 | 08:52 PM
  #103
99f350sd's Avatar
99f350sd
Hey guy's anyone know of some company that makes a rack or platform for the top of our trucks to mount lights etc. The majority of the roof is flimsy but there are 2 channels that may be stronger for mounting...I have two 24 " led bars and an emergency light up there mounted to two massive k40 magnets..Works well but is heavy. All that crap is mounted to a 12x24 inch piece of stainless. When I hit a bump sometimes the roof flexes..
Dick
Old Jun 28, 2014 | 02:11 AM
  #104
Yahiko's Avatar
Yahiko
99f350sd,
For you mount why not use some of the channel from 80/20® Inc. - The Industrial Erector Set®
All types of ways and you can still use the magnets.
Miles,
Thanks for the work light info.
Sean
Old Jun 28, 2014 | 07:12 AM
  #105
99f350sd's Avatar
99f350sd
Possibly but I need a way to mount to truck...
