C6 Question
Old Jun 13, 2014 | 05:47 PM
SuperDuty93's Avatar
SuperDuty93
C6 Question
I have a friend who is replacing his 460 with a 428 CJ in his highboy. Now I believe the motor mounts are different correct?
But here is the real question. Can we take the short tail shaft off the 460 c6 and put it on the rebuilt 2wd C6 he has for a FE? Or are the transmissions completely different and not just the bellhousing? Since it is a highboy the tailshafts are different from a 2wd.
Thanks!
Old Jun 13, 2014 | 07:51 PM
grinnergetter's Avatar
grinnergetter
Engine mounts are different but should be pretty easy to find.
I took an output shaft and adapter from a 77-79 4wd C-6 and swapped it into a FE C-6 2wd with no issues.
Edit, I tried the FE in the later 351 4x4 style mounts and you can see how that worked out here...https://www.ford-trucks.com/forums/1...get-build.html
Old Jun 14, 2014 | 07:11 AM
redroad's Avatar
redroad
The 2wd trans won't have the transfer case shift linkage mounting points on it ..
Old Jun 14, 2014 | 11:51 AM
SuperDuty93
If I switch out the tailshaft wont that have the mount on it? I better go look at my highboy
Old Jun 14, 2014 | 06:41 PM
co425's Avatar
co425
Yes, the shifter bung is on the tailshaft on a highboy.
Old Jun 15, 2014 | 03:17 PM
SuperDuty93
Cool thanks. Now any idea of what seals ill need to go buy in order to swap tails and then put both transmissions back together?
Kjreed2087
Nov 26, 2020 12:10 PM
f-100 buster
Jun 13, 2006 06:25 PM
c_rossman
Jul 23, 2003 11:28 AM
30over
Aug 23, 2002 06:26 PM
90Bronc
Jul 30, 2002 02:59 PM
