Anyone have any idea where I can get the tail housing adapter to attach a borgwarner 1356 to my c6 transmission? Iv Got the output shaft but no adapter.
I’m a couple years late to the party but I’m in the process of doing the same thing to my 88 F350 with the C6. I bought a 1984 F350 with a t-19 and a BW 1345 transfer case and am looking for an adapter and shaft. (From what I can find the BW 1345 and BW 1356 use the same adapter)
The bolt pattern for the BW 1356 is apparently the same as the np205. So if your bolt patterns are the same as those. It should work. The part number I got was D7TP-7A040-BA
be sure to check the output shaft length of your transmission pretty sure ford made a longer adapter for an 8 inch output.
