2002 7.3 IDM issue
Old Jun 19, 2014 | 08:25 AM
Pikachu's Avatar
Pikachu
How exactly did you take the readings? From where? 3.6 ohms doesn't indicate a problem; the solenoid resistance is about 2.9 ohms at somewhere around room temperature.
Old Jun 19, 2014 | 11:56 AM
cherrybomb37's Avatar
cherrybomb37
With the valve cover off and wiring harness attached still from points 3-4-6-7 and the ground pin 5. Everybody has said 3.6 is perfect. I am more interested to know the voltage/Ohms that the pigtail is suppose to have with the key on. I believe that's the issue otherwise the harness from the 42 pin is $1,049!!!!!!!!! Or just try the Ford replacement pigtail with connectors and shrink wrap for $34.45 that's even cheaper than a Dorman replacement.
Old Jun 19, 2014 | 12:15 PM
Pikachu's Avatar
Pikachu
What do mean with the key on? There's no valid measurement I know of for that with the key on. Did you pull the 42 pin connector off and check the underside of the chassis side harness for chafing? You can check resistance from the IDM connector to verify the complete path from there to the injector solenoids, too.
Old Jun 19, 2014 | 01:08 PM
cherrybomb37
yes I have done the 42 Point It was fine. the key on vs off will give a reading from the 9 point harness.
Old Jun 19, 2014 | 01:10 PM
Pikachu's Avatar
Pikachu
I'm not sure I follow what you're saying here.
Old Jun 19, 2014 | 04:40 PM
cherrybomb37
if you have the key off the 9 point connectors from the 42 point, the 9 points that connect to the UVCH. They will be a dead zero. if you have the key on the run position without the engine running they will give off some voltage not much but enough to see if the wires actually work.
Old Jun 19, 2014 | 04:50 PM
Pikachu's Avatar
Pikachu
What matters is the resistance from the IDM through the injector solenoid and back. Measuring resistance from the harness to the IDM and back is pointless since you'd be trying to measure through the IDM.
Old Jun 19, 2014 | 11:26 PM
Tugly's Avatar
Tugly
There is no criteria for reading backwards from the connector at the VC gasket - key on or off. Whatever readings you are getting, you're all alone - with no reference or support.
Old Jun 20, 2014 | 08:09 AM
cherrybomb37
some guy on here told me that ..... well that was some useful information... Well I already loaded her up on the flatbed to take in Monday dealer will hopefully have the final say
hickory1991
Feb 2, 2019 07:15 PM
ITSOT
Aug 28, 2017 05:23 AM
DieselFNG
General Diesel Discussion
Apr 15, 2017 11:25 AM
drizzie27
Mar 28, 2012 06:08 PM
ratpack4
Jul 20, 2009 02:31 PM
