Odd ball rear
Old Jun 24, 2014 | 12:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by turbohunter
The center section is not shaped like the 80s that we are used to now days as they are much beefier.
It is a floater. Sorry for the miss info. I haven't had it apart in years and have had so many others apart lately I just miss remembered. I hate getting old.
The vin plate says the truck should have a 9 inch with 3.0s in it (A1).
A1 = Spicer/Dana 44 Rear Axle / 3.73-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
Old Jun 24, 2014 | 01:00 PM
turbohunter's Avatar
turbohunter
Whoa, thats interesting.
Thanks ND
That makes the decoder I was using a liar.
I think that's the first time I've ever gotten misinformation off the web.
Old Jul 2, 2014 | 09:24 PM
55f100tx's Avatar
55f100tx
That is a Dana 80 center for sure. ford put 8 lug 80's in some E350 and 450 vans with 4:10 gears. dodge also used 8 lug 80's. On the axle tube you may find a build date code stamped in. the 80 cast into the housing is the truth, that's the way Dana marks their rearends.
Old Jul 3, 2014 | 01:44 PM
1964FORDTUF's Avatar
1964FORDTUF
55f100tx - Can you pass along what years Ford did that in the vans? This gives me an idea. Thanks!
Old Jul 3, 2014 | 03:34 PM
schoo's Avatar
schoo
I got one that looks like that
Old Jul 3, 2014 | 03:39 PM
schoo's Avatar
schoo
Wheel is even close I bet it'll be just fine
Old Jul 4, 2014 | 02:51 PM
55f100tx's Avatar
55f100tx
1996 to 1999 E350 1999-2000 E450 They came in the cab and chassis models, look under a U haul. other years may be available. The E450 is wider than the E350 axle.
Old Jul 4, 2014 | 05:53 PM
1964FORDTUF
Thanks a million!
john jamieson
Sep 9, 2017 11:38 AM
jgavac
Nov 4, 2011 10:41 PM
f150460
Jul 16, 2011 06:21 PM
Jolly Green
Jun 16, 2008 09:26 AM
Eagle131
Offroad & 4x4
May 25, 2002 03:04 PM
