No FICM Sync
Old Jun 14, 2014 | 12:27 PM
BLADE35's Avatar
BLADE35
Change the ICP sensor see what happens
I get the feeling your gauge isn't reading things correct But IDK
OR you really don't Have Sync
But if the CMP CKP sensors are checking Out OK then and sounds like they are so
I wouldn't even worry about anything other then the Compleate Obvious and that's Changing the ICP Sensor at this point
The ICP sensor is Clearly Bad
It Should default unplugged and let the truck start
You reported a Cranking RPM of 257rpm I don't think our starters can Achieve that fast so there Could be something wrong with sync/pcm IDK 100% yet it does seam alittle out of Whack
I just have a Hard time to believe you have Multiple Problems that are Unrelaited systems that all happened at same time
IMO you change ICP sensor and see what happens its Clearly BAD then if it still don't start Move On
I forgot to tell you to there 1 more harness for Sync to check and that's From PCM to FICM Itself!! What I posted was only from PCM to CMP/CKP Sensors
It almost makes sense the PCM Failed But I would like to see a New ICP sensor installed and Clean or replace ICP pigtail see what happens with new ICP sensor since it will need to be change regaurdless
Old Jun 14, 2014 | 12:35 PM
BLADE35's Avatar
BLADE35
When you look at Sync are you cranking long enough for the Gauge to Update???
I honestly wouldn't do anything until the ICP issue is Fixed
Therers been a few problems with Gauges out there being able to Read Sync I am not framiliar with your gauge so IDK
Old Jun 14, 2014 | 05:53 PM
Punkfish's Avatar
Punkfish
Hi Josh, Thanks for your continued interest, it's always good to get a little food for thought. First let me correct the RPM that should have read 157 (but I have seen it reach 190).
The reason I'm working it this way is that I still don't have the ICP sensor and pigtail in hand. I did disconnect the ICP but it still didn't start and it still showed no sync to either CMP/CKP or FICM. I did think it was strange to have two completely different faults at once, but I know it's possible (when I was working aircraft I'd see it all the time). When I first started troubleshooting I had the bad ICP and the no FICM sync but then ended up losing the CMP/CKP sync as well, when I did get sync originally
It would come on in a few seconds. I know I need both parameters to start so I worked the sync issue while awaiting parts. I'm 99.9% I don't have an issue with my diagnostic software, I also did the pin to pin on the FICM TO PCM harness with no defect noted.
I'll keep you posted on my progress as soon as I start getting parts in, if you can think of anything else I'd appreciate you input.
Gary
Old Jun 14, 2014 | 06:44 PM
BLADE35's Avatar
BLADE35
Check Fuse under steering wheel
#F2-22
#F2-36
And also relay #302 is the PCM power control
These^^Fuses or relay could cause NOSYNC
Your RPM is wiythin spec of 150-200rpm range so that good
Old Jun 14, 2014 | 06:50 PM
bismic's Avatar
bismic
I have read that if you lose CKP signal, your HPO readings could default to 14% IPR and 300 psi ICP (would love for a Tech to confirm that - I think it is in the PC/ED manual!). This is one reason Ford recommends troubleshooting CKP/CMP SYNC issues first (assuming that the scan tool is reporting that correctly and it really is dropping out).
That being said, If you know you have bad sensors, nothing wrong w/ changing them out as soon as possible.
Edit -
Was reviewing no-start info and came across a reference to an old reference to a "shorting out EBP sensor" causing PCM issues. Might be worth a try (try starting w/ EBP unplugged) while you wait for the ICP sensor.
Old Sep 2, 2015 | 11:40 AM
1977scoutii's Avatar
1977scoutii
2005 F350 6.0
Can someone explain the difference between Sync and FICM Sync?
I notice on the Scanguage when starting, Sync will go to 1 before FICM Sync will.
Old Sep 2, 2015 | 12:22 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by 1977scoutii
2005 F350 6.0
Pcm FICM synch
Cam sensor crank sensor synch
Josh
Old Sep 2, 2015 | 01:49 PM
1977scoutii
Thanks,
I understand Cam sensor and crank sensor sync, which injectors to fire and when.
Concerning FICM Sync, does the signal simply pass from the Crank and Cam sensors to and through the PCM to FICM or does the PCM do something with the signal prior to sending to the FICM? What constitutes a FICM Sync?
Looking at the schematic:
Cam Position Sensor is wired directly to the PCM on PCM Connector C1381bpins 31 and 43
Crank Position Sensor is wired directly to the PCM on PCM Connector C1381bpins 30 and 41.
Then from PCM to FICM:
Cam Position signal PCM Connector C1381c pins 20 to FICM Connector C1388CPin 10
Crank Position signal PCM Connector C1381c pins 19 to FICM Connector C1388CPin 5
Old Sep 2, 2015 | 02:11 PM
Bullitt390's Avatar
Bullitt390
In a nutshell the PCM is getting feedback that the engine is turning over, once 150 rpm is achieved and 500 psi the FICM is brought on board, hence PCM/FICM synch.
Josh
Old Sep 2, 2015 | 02:32 PM
1977scoutii
That is what I was looking for, thanks!
BRay09
Mar 8, 2023 07:57 PM
Schlu42
May 9, 2017 06:15 AM
Eth12
Mar 23, 2017 08:38 PM
hondamanex400
Apr 1, 2016 10:47 PM
jshalala
19
May 29, 2014 07:20 AM
