stuck bolt
Old May 30, 2014 | 07:50 PM
lotech's Avatar
lotech
stuck bolt
The down spout out of the water pump is where. I tried to turn it and the head broke off. I tried to heat it up, that didn't work. I soaked it in PB Blaster overnight and was no help. I tried drilling it and it's a hardened bolt, 10.9 . Any pros got any idea ? I'm working on this in my driveway. What a mess I made.
Old May 30, 2014 | 08:46 PM
bigb56's Avatar
bigb56
Are you able to get the water pump off? Is there any of the bolt still sticking out?
Old May 30, 2014 | 08:50 PM
helifixer's Avatar
helifixer
is the shank of the bolt exposed?
if so get a nut that will slide over it and weld it on to the shank, I weld them hot and a lot so it super heats the bolt, let it cool below red hot put a wrench on it and wiggle it, if it moves any just walk away and let it cool to almost cool to the touch than flood it with pb blaster to cool it all the way than start moving it in and out while flooding with the pb until it comes out.
Pikachu's Avatar
Pikachu
For all the trouble it's going to be to get it out of there, I'd replace the water pump. Just sayin'.
Old May 30, 2014 | 09:00 PM
lotech's Avatar
lotech
The bolt broke very close, I may get the pump off and then I may just buy another pump. I don't know how old this one is. I might have one eight inch on it. My 97 truck never gave me this much trouble. I'm begining to think this truck was flooded a long time ago. So many stuck and rusted bolts for only 265 k. I 've never had one that was this stuck. I even got a HPOP line stuck, but I can cut it off.
Old May 30, 2014 | 09:01 PM
JWC 3's Avatar
JWC 3
7.3 ? I just put a pump on one the other day . Came with a new outlet and new bolts . Save some headache .... Replace the pump .
Old May 30, 2014 | 09:04 PM
lotech's Avatar
lotech
Yep, sounds better to me. The only part I havent replace is the altenator and ac.
Old May 30, 2014 | 10:32 PM
Tugly's Avatar
Tugly
The pumps are rumored to go out about every 130K to 140K miles. I just had the 2nd replacement at 275K. If this happened to Stinky with those miles on the pump, I'd pull the pump and start over... as well as a new thermostat housing.
Old May 31, 2014 | 07:42 PM
Christof13T's Avatar
Christof13T
This would be a great opportunity to put in an international pump with built in filter housing...
If you are having this much trouble with the one bolt... if it were me, they would all be replaced. I usually have good luck finding bolts for these engines at lowes. Each hole would get a bottom tap run in to clean the rust out of the thread roots... then treated with anti-seize.
blrman1962
Jun 19, 2012 02:56 PM
f-250diesel
Dec 31, 2010 09:01 AM
Archion
15
Apr 14, 2009 01:28 PM
-jeremy
Garage & Workshop
16
Jun 16, 2006 04:11 PM
Mr Ed
Jul 26, 2004 03:23 PM
