bolt broke in water pump. what now???
so i went to go replace my thermostat today and i noticed that there was a 10mm bolt and a two 8mm bolts, so i took the front two off but the back one broke in the water pump. i think that some one put the wrong bolts. there was also all kinds of silicone. i dont know what to do any sugestions
I broke mine off, so I took the water pump off (not a hard job really, and cheaper than a new pump) drilled it out, tapped a slightly larger hole and used SAE bolt upsidedown so it was a stud sticking up and jb welded the bolt in the hole. I filed a flat spot on the underside so the bolt head could not turn.
So now you have a stud sticking up in back and you just drop a lock washer and nut on and never have a problem again. It worked so well I wanted to do the same thing to the other 2 but said to heck with it.
Another vote here to just get a new neck, don't fight the old one, it's not worth the $40 savings to always battle the leak.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
wirelessengineer
20
11-18-2016 08:13 PM
NotSoSporty98
08-14-2016 12:53 PM
mdredneck
12-22-2013 09:36 PM
Ole Green 1978
15
02-24-2012 05:42 AM
