AC condenser replacement options
1968/72 F100/350: Factory installed integral A/C is combined with the heater. The A/C controls are located in the same panel as the heater controls.
C8TZ-19712-A .. A/C Condenser-Use with factory installed integral A/C (Motorcraft YJ-18) / Obsolete
1968/71 F100/350 - 1972 F100/350 before serial number N40,001.
No Ford dealer or obsolete parts vendor has any.
D2TZ-19712-A .. A/C Condenser-Use with factory installed integral A/C (Motorcraft YJ-62) / Obsolete
1972 F100/350 from serial number N40,001, before serial number P40,001.
D3TZ-19712-A .. A/C Condenser-Use with factory installed integral A/C (Motorcraft YJ-27) / Obsolete
1972 F100/350 from serial number P40,001 / 1973 F100/350 before serial number S20,001.
NOS ONLY in San Jose CA has 1 = 800-667-6659.
1973/79 factory installed integral A/C: All the components fit into the dash, there no "hang-on" bezel like the 1968/72 system has. Ditto 1980 and later.
Suggestion: Take the truck to an A/C shop, see if they have a condenser that'll work.
<TABLE id=post4830653 class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR><TD class=thead>06-11-2007, 11:18 PM <!-- / status icon and date -->
</TD></TR><TR><TD style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=alt2><!-- user info --><TABLE border=0 cellSpacing=6 cellPadding=0 width="100%"><TBODY><TR><TD class=alt2>
Ford Parts Specialist</TD><TD width="100%"> </TD><TD vAlign=top noWrap>Join Date: Nov 2006
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR><TD id=td_post_4830653 class=alt1><!-- message, attachments, sig --><!-- message -->Quote:
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Originally Posted by wantaford
It mounts vertically on the drivers side!
Vertical left mounted dryer = FoMoCo factory A/C. Top mounted dryer = Ford dealer installed A/C. Both the factory and Ford dealer air look very similar 1967/72, that's why I asked the question initially.
The original condenser C8TZ-19712-A, was replaced by Ford in 1973, with D3TZ-19712-A (1967/73). 1974/79 uses a condenser/dryer assembly. The hoses will have to be changed to use the 1974/79 condenser D8TZ-19712-A. on the 1967/73 models.
<!-- / message --><!-- sig -->__________________
Bill / Retired Ford Parts Manager / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
<!-- / sig -->
August 2008, I read in the local newspaper that Pasadena Ford was closing, I needed a Ultra VII viewer so I called the P/M and asked if he had one.
No, he said...what do you want one for? (I thought his 'Bronx honk' sounded familiar). I told him. He said...who is this? I told him.
He said, Bill it's Bob, get your azz over here ASAP, you can have everything!
Everything included over 600 slides, 2 viewers, 60 bound paper and loose leaf catalogs and a lotta other crapola. When all was loaded, my new Fusion's rear bumper was only a few inches from the ground.
1969: P/M at Beverly Hills Ford hired a new driver/trainee for the back counter. He was fresh from the Bronx and I was the back counter guy.
No, he said (I thought his 'Bronx honk' sounded familiar). He added...what do you want one for? I told him. He said...who is this? I told him.
Everything included over 600 slides, 2 viewers, 60 bound paper and loose leaf catalogs. When all was loaded, my new Fusion's rear bumper was inches from the ground.
1969: P/M at Beverly Hills Ford hired a new driver/trainee for the back counter, he was fresh from the Bronx and I was the back counter guy.
Here's one on eBay item number
231071316523
Orich
Automotive Ac Condenser, Fan Assembly - Auto Parts at Partsvalley
