Aftermarket AC Condensor
Old Aug 24, 2016 | 05:32 PM
maverick600's Avatar
maverick600
I am trying to find a condensor that is as close to OEM as possible. I ordered one from Advanced and it would not fit in my truck, the pipe on the pass side at the bottom was hitting the side because of how much it bent out. Little difficult to describe and I don't have a picture but I am hoping that maybe someone has a part number or maybe ND would be willing to give me a part number I can google and go from there. It's factory air and has a automatic trans.
Old Aug 24, 2016 | 06:58 PM
FuzzFace2's Avatar
FuzzFace2
This is what I got from member Parr4
Rec'd my new condenser today. When you are needing one the correct Ford OEM #E0TH19710
Dave
Texas
__________________
Dave S(Texas)
'81 F100, bought New, 300-6/MT/Fac AC (R12)
'87 Coupe DeVille/new engine Dec '08
2003 FXDL
Retired Member IBEW Lu 520
I know he was having issues getting one that would fit his truck.
I think he got it thru Ford but not sure.
I am far off time wise needing one but I am thinking of taking measurements ofmy old one then look here Painted - Parallel Flow Condensers | ACKITS.com for the largest one that will work in my truck.
Dave ----
Old Aug 24, 2016 | 07:22 PM
maverick600
Thanks for the reply, I tried googling that part number and nothing came up. I don't want to go universal unless I absolutely have to. I'll hold out as long as I can.
Old Aug 25, 2016 | 05:20 AM
FuzzFace2's Avatar
FuzzFace2
Look for posts from parr4 or pm him what he did and where he got the number & part from.
Dave - - - -
Old Aug 25, 2016 | 05:55 AM
Franklin2's Avatar
Franklin2
Go to rockauto and see if it's any help. They don't have any in stock but they list two different ones, a
APDI/PRO 7013605 and a
VARIOUS MFR FO3030133 {#CND36053, E7TZ19712A} Alternate/OEM Part Number(s): CND36053, E7TZ19712A
These different numbers may help in a google search.
Old Aug 25, 2016 | 10:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by maverick600
I tried googling that part number EOTH19710 and nothing came up.
Not surprising, because...
This is not a part number, it's the ID engineering number marked on the part itself.
Is the condenser for your 1986 F150 with factory A/C? If so...
E7TZ-19712-A (replaced EOTZ-19712-A) .. A/C Condenser-Use with Factory Installed Integral A/C (Motorcraft YJ-234) / Obsolete ~ 26 available NOS
1980/82 F100/350 & Bronco / 1983 F100/350 & Bronco with gas engines / 1984/88 F150/350 & Bronco gas/diesel engines / 1989 F250/350 diesel.
Old Aug 25, 2016 | 12:22 PM
kr98664's Avatar
kr98664
How about this one?:
COND F SERIES 80-93 BRONCO 80-89 YJ-234
No idea how this particular item fits, but I've had excellent results with other stuff from Arizona Mobile Air.
Old Aug 25, 2016 | 12:29 PM
NumberDummy
No idea how this particular item fits...
See post #6
Old Aug 25, 2016 | 05:14 PM
maverick600
Thank you ND!!
Old Aug 25, 2016 | 05:15 PM
maverick600
Thanks for looking out!! I'll bookmark this site for sure!
Old Aug 26, 2016 | 04:53 PM
maverick600
Yes it is, is there a number to call or just look up NOS online?
Old Aug 27, 2016 | 07:22 AM
FuzzFace2's Avatar
FuzzFace2
Part of the issue Parr4 ran into was the parts all had the right part number but did not fit "right". I don't remember just why it would not fit at this time.
It sounds like we have different "needs" for the condenser. you want stock I want something that will work.
Because I am changing to 134a and I hear the R12 condensers are a little too small for 134a I want to go as big as I can.
I also don't know what compressor I am going to use, York the truck came with or Sedan. I need to find or make bracket for either compressor.
So I may need to make up hoses for either compressor or condenser.
Let us know what you come up withand from who.
Dave ----
edit: I want to say I remember Parr4 had issues with after market condensers and he found the right one thru a Ford dealer.
Old Aug 27, 2016 | 11:40 AM
NumberDummy
Are there numbers to call?
E7TZ-19712-A (Motorcraft YJ-234) =
HAVEN FORD in Haven KS has 1 = 620-465-2252.
DUST & SON MOTORCRAFT in Effingham IL has 1 = 217-342-2147.
LAFOURCHE FORD-LINCOLN in Lockport LA has 1 = 800-375-5547.
PERRY PITRE FORD in Eunice LA has 2 = 337-457-4111.
RPN PARTS in Erie PA has 3 = 888-864-9305.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
VINTAGE PARTS INC. in Beaver Dam WI has 11 = 877-846-8243.
Old Aug 27, 2016 | 01:01 PM
maverick600
Dave ----
I have tried an aftermarket one as well and had the same problem, it did not fit so that is why I am looking for the right one. I am on the fence about using 134 or 12. I have access to 12 and yes the original one does not disperse the heat as well for the 134 to work as well with the old system. When I was working on my 71 with factory air I had to go with a universal one and had to make brackets for it to fit.
Old Sep 1, 2016 | 04:53 PM
maverick600
I talked to a guy in LAFOURCHE that was very helpful and his was damaged but told me that YJ-234 was superseded by YJ-261. Would this be the same thing?
