Sponsored by: Real Truck
Help Finding A Wire
Old May 20, 2014 | 10:07 PM
fancyvern's Avatar
fancyvern
Help Finding A Wire
On a 2012 F-450 I need help finding a wire. In the middle of the dash there are a row of rocker switches. Can anyone tell me where they exit. I need to hook on to one if possible out side of the cab in the engine area. Outside anywhere would be helpful.
Old May 20, 2014 | 10:24 PM
TosaFords's Avatar
TosaFords
If you are talking about the OEM Upfitter switches there are Capped wires under the left side of the steering column. Look in your owners manual under the Upfitter Switches section for information on the Max Amperage of each switch as well as color coding on the wires and their location.
Old May 20, 2014 | 11:22 PM
fancyvern's Avatar
fancyvern
Thanks for the help. I want to excite a solenoid to run a little compressor.
Old May 21, 2014 | 08:26 AM
Fleetsuper's Avatar
Fleetsuper
This will help you
https://www.fleet.ford.com/truckbbas...ml/Q117-R2.pdf
Tmarshallg
Jul 28, 2017 04:04 PM
BCM
Mar 10, 2017 08:01 PM
co997
May 9, 2016 06:35 PM
Robert6401
15
Oct 2, 2007 07:26 PM
temec250
May 24, 2007 04:25 PM
