Sponsored by: Real Truck
Accessory power under dash 2015
Old Apr 2, 2015 | 06:54 AM
co997's Avatar
co997
2015 F250 diesel. I am hooking up an air pressure gauge inside the cab to report the pressure on my rear aftermarket air bags. The pressure reading will come from a tap on the actual pressure line, but I need 12vdc to operate the backlight on the gauge. I have found a bundle of loose wires under the steering column, 4 of which are firewall pass-through wires for the upfitter switches. Does anyone know if one of the remaining wires in the bundle is an accessory power wire? I need a plain key-on accessory wire connection, not a dash-light connection.
I am using one of the upfitter switches to switch my on-board air compressor and a second switch to inflate/deflate the air bags. Want to save the other 2 switches for future use.
Old Apr 2, 2015 | 07:18 AM
Just Strokin's Avatar
Just Strokin
Look for a white with blue stripe wire taped with the upfitter wires. This wire per diagram is suppose to be customer access and hot in run/acc position. This is not one of the upfitter wires.
Old Apr 2, 2015 | 08:58 AM
co997's Avatar
co997
Thanks for the info, Larry. Can you tell from the schematic if one of the wires in that bundle is a ground, or do I need to find a ground somewhere else?
Old Apr 2, 2015 | 10:02 AM
Just Strokin
no, you should have some ground wires in the kick panel or close by. Black is the wire color used for grounding.
Old May 9, 2016 | 02:38 PM
Maverick163's Avatar
Maverick163
Quick question. Besides poking each of the loose wires under the dash with a VOM to figure out which one is hot. Does anyone know which ones are ignition hot for trucks without upfitter switches. I'm hooking up power to my trailer rear camera monitor. I know I can buy upfitter switches and add them latter, but for now what wire is ignition hot.
I'd rather not go about stripping them to figure this out. In the meantime I will surf the net for wiring diagrams.
Old May 9, 2016 | 04:22 PM
IDI Diesel's Avatar
IDI Diesel
Where are you mounting the pressure gauge inside the cab? I have OBA but no gauge because I haven't found a clean way to mount it. Post a pic once you install it. In other vehicles I always pull 12V keyed power from a cigarette lighter
Old May 9, 2016 | 06:21 PM
ATP Pilot's Avatar
ATP Pilot
up and behind the Parking brake. I used that wire not long ago.
Old May 9, 2016 | 06:35 PM
Maverick163
I decided to go ahead and add the upfitter switches to make it cleaner. What's another $150 bucks.
amcginthy
Jul 25, 2018 06:42 PM
bryanmartin
Apr 25, 2018 12:01 PM
BCM
Mar 10, 2017 08:01 PM
Ray Hamel13
Aug 21, 2014 06:13 AM
dmallen
Jul 12, 2014 07:52 PM
