Aux switch wire locations - 2016 F250
Nothing is pre-wired. There are wires run thru the firewall to the engine bay. You will need to locate the up-fitter wires under the dash just above your left foot area. Then connect whatever switch you are using (#1-#4) to the pass thru wire. Then go to the engine bay, connect a lead to the pass thru wire to your light power.
superduty4x4
15
09-06-2021 10:50 PM
